Old 05-30-2013, 11:17   #1 (permalink)
Member: 1824929
Thanks Meter: 99
nokia x1-01 no signal
nokia x1-01 no signal i change pa ic change an****a change power but no siganal
any solution plzz helllp
Old 05-30-2013, 13:10   #2 (permalink)
mahzra azra's Avatar
Member: 1722956
Sonork: mybestfriend.adeel
Thanks Meter: 305
power???????
how many ic did you change???
can you tell us????
Old 05-30-2013, 13:17   #3 (permalink)
Member: 1824929
Thanks Meter: 99
i change power ic flash ic signal ic and change every resistance but no signal
Old 05-30-2013, 15:32   #4 (permalink)
Member: 1824929
Thanks Meter: 99
any one helllp meeeeeeeeeeeeeee
Old 05-30-2013, 18:09   #5 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,350
post here selftest result
Old 05-31-2013, 10:43   #6 (permalink)
Member: 1722956
Thanks Meter: 305
[bro,leave this this phone and again repaire that set inwhich you take power and flash ic for your network set.
That pair ,you removed from network problem set that pair again set on dead set now.i hope this phone will be ok.
If you have any problem contect me on----
[email protected]
i will sure help you to solve it.]
Old 05-31-2013, 11:05   #7 (permalink)
gsmretorque's Avatar
Member: 1902151
Thanks Meter: 61
re hot big ic bro or try this hard ware solution
The Following User Says Thank You to gsmretorque For This Useful Post:
Old 05-31-2013, 17:35   #8 (permalink)
Member: 1824929
Thanks Meter: 99
i also did this method but not work.....no signal
Old 06-01-2013, 00:01   #9 (permalink)
Member: 1902151
Thanks Meter: 61
check your pcb board bro..sometimes the balls or the contact is not feted..
Page generated in 0.15282 seconds with 8 queries
