nokia 1616 rh-125 14 BAD RSA SIGNATURE hai brother i have one nokia 1616 i full flashed that phone the phone working ok but white display show, but in file info that show lcd MCU SW : V 05.80 06-08-10 RH-125 (c) Nokia PPM SW : V 05.80 06-08-10 RH-125 (c) Nokia EL Platform: Infineon Prd.Code: 0595840 Bpr.Code: 059F8R0 Prod.Sn : 9683C76AI HW Vers : 1014 UEM : 1328 UPP : 8850 [2292] LCD Type: WIN:BAFFINv80 NT39121 IMEI : xxxxxxxxxxxxxxxxxxxxxxxx SL Conf : 001-01-00000000000 SL Prof : 000000000003000-2 SL Var : 00003578760458753300 SL Aux : 000B0000 HW Sig : 5ACA5B1BFBC23467 Box Id : FFFFFFFFFFFFFFFF BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN Provider: GSM Test Equipment in U I setting shows IMEI: xxxxxxxxxxxxxxxxxxx, ASIC: 11 Writing SimLocks Failed: 14 BAD RSA SIGNATURE SimLocks Init Failed UI Defaults Ok, Time: 00:01 Set UI Factory Defaults Ok, Time: 00:00 Set Full Factory Defaults Ok, Time: 00:01 Set Software Upgrade Defaults Ok, Time: 00:00 Set Security Ok, Time: 00:00 Init Normal Mode Ok, Time: 00:02 pls help |
Hi brothers I also have same issue in Nokia 101 IMEI: 359069-04-623764-2, ASIC: 11 Writing SimLocks Failed: 14 BAD RSA SIGNATURE SimLocks Init Failed UI Defaults Failed Some 1 Please reply me |
facing the same in nokia 1616 if anyone have solution please update thank full to all |
ektapatel hai brother i have one nokia 1616 i full flashed that phone the phone working ok but white display show, but in file info that show lcd MCU SW : V 05.80 06-08-10 RH-125 (c) Nokia PPM SW : V 05.80 06-08-10 RH-125 (c) Nokia EL Platform: Infineon Prd.Code: 0595840 Bpr.Code: 059F8R0 Prod.Sn : 9683C76AI HW Vers : 1014 UEM : 1328 UPP : 8850 [2292] LCD Type: WIN:BAFFINv80 NT39121 IMEI : xxxxxxxxxxxxxxxxxxxxxxxx SL Conf : 001-01-00000000000 SL Prof : 000000000003000-2 SL Var : 00003578760458753300 SL Aux : 000B0000 HW Sig : 5ACA5B1BFBC23467 Box Id : FFFFFFFFFFFFFFFF BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN Provider: GSM Test Equipment in U I setting shows IMEI: xxxxxxxxxxxxxxxxxxx, ASIC: 11 Writing SimLocks Failed: 14 BAD RSA SIGNATURE SimLocks Init Failed UI Defaults Ok, Time: 00:01 Set UI Factory Defaults Ok, Time: 00:00 Set Full Factory Defaults Ok, Time: 00:01 Set Software Upgrade Defaults Ok, Time: 00:00 Set Security Ok, Time: 00:00 Init Normal Mode Ok, Time: 00:02 pls help |
do we have to make a Downgrade or an upgrade to Unlock this phone if some came up with a solution please Share |
