01-07-2012, 15:03 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: india Age: 39
Member: 725038 Status: Offline Sonork: 100.1675584 Thanks Meter: 288 | nokia 1616 ST_LCD_TEST : FAILED help me chenj to lcd softwer upgred is ok bat same probalem pls help me VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... CPU ID Response: A200341100 CPU Type: XG110 2.1B Phone Booted at after First attempt... ************************************************** **** TIME STARTS HERE ************************************************** **** Sending PBL 19456 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer: STMicroelectronics Flash Chip Type: M58WR064 64 Mbit (4Mb x 16) NOR Extended Information: Multiple Bank / Burst / 1.8v Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RH-125\rh125_005.800 FIRMWARE Image Found... Number of Sections: 03 FIRMWARE Certificate Block Sent Successfully... Processing Section 01 of 03 FIRMWARE Erase Block: 0x00800000~0x00A0FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2162688 bytes Data Checksum: 578C Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 of 03 FIRMWARE Erase Block: 0x00C60000~0x00EAFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2131008 bytes Data Checksum: 3B67 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 of 03 FIRMWARE Erase Block: 0x00FFC000~0x00FFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 64 bytes Data Checksum: 0000 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RH-125\rh125_005.80mg PPM Image Found... Number of Sections: 01 PPM Certificate Block Sent Successfully... Processing Section 01 of 01 PPM Erase Block: 0x00210000~0x0043643E Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2253888 bytes Data Checksum: F5FB Uploading Data Blocks to phone... PPM Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RH-125\rh1250_nai05.80mg_nlt CONTENT Image Found... Number of Sections: 01 CONTENT Certificate Block Sent Successfully... Processing Section 01 of 01 CONTENT Erase Block: 0x00EB0000~0x00F707BE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 788416 bytes Data Checksum: 77C3 Uploading Data Blocks to phone... CONTENT Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Exit Flash Mode Done... Time Elapse : 00:03:18 ************************************************** **** You must Factory Reset the phone to enable the ringtones and other customized settings to work ************************************************** **** Waiting For Phone to go Online... 5, 4, 3, 2, 1... MCU: V 05.80 06-08-10 RH-125 (c) Nokia IMEI: 353775043942929 Product Serial Number: 2AB8C18AI Product Code : 0595840 Module Code : 0204343 Basic Production Code: 059C283 PPM SW Version : V 05.80 06-08-10 RH-125 (c) Nokia MG ADSP Version : p+V 05.80\n06-08-10\nRH-125\n(c) NMP\nmg_nlt MCU SW Version : V 05.80 06-08-10 RH-125 (c) Nokia HW Version : 1002 UEM Version : 1328 UPP Version : 8850 LCD Version : UNKWN: IDs: 00:00:00 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 0000000000030002 ASIC : 11 PROVIDER : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_LCD_TEST : FAILED Phone Cannot Enter Normal Mode if LCD is Damaged or LCD is not Properly Connected to the Main PCB FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK |
