12-07-2009, 03:10 | #10 (permalink) | |
Freak Poster Join Date: Sep 2009
Member: 1114923 Status: Offline Thanks Meter: 224 | Quote:
( no call ) maans, it is not any factor of display as well as display connector .so try to flash with update verson if not ok then rehot upp.it also can be contect service problems, so try to unlock also .it will must be ok i faced this problems many time and become successfull all time | |
12-07-2009, 04:51 | #12 (permalink) |
No Life Poster Join Date: Mar 2007 Location: IN FRONT OF YOU Age: 44
Member: 475440 Status: Offline Sonork: 1604067 Thanks Meter: 965 | its the problem of upp rehot it with past use good past and give a normal heat and push a little if not change 100% tested method this problem is comes becoz of bad upp Br Asghar Hussain |
01-26-2010, 15:32 | #13 (permalink) |
Banned Join Date: May 2007 Location: bagalkot
Member: 511488 Status: Offline Thanks Meter: 8 | 1650 blue lcd 1000% ok 1st self tset using jaf or hwk if lcd test passed just flash hand set 1000% ok if fail change lcd connector 100% k tested by veer mobitech bgk mob 9901251785 |
01-31-2010, 14:07 | #15 (permalink) | |
No Life Poster Join Date: Dec 2007 Location: B.DESH (narayangonj) Age: 39
Member: 648428 Status: Offline Thanks Meter: 846 | Quote:
change display connector http://forum.gsmhosting.com/vbb/showthread.php?t=585543 | |
1650 blue display | ameerali19 | Nokia Hardware & Hardware Repair | 17 | 07-15-2010 09:43 |
1650 blue display help | vaghubha_sodha | Nokia Hardware & Hardware Repair | 7 | 07-25-2009 17:24 |
nokia 6111 sometime blue display sometime ok,help me | shivam4you | Nokia Hardware & Hardware Repair | 1 | 05-30-2009 14:39 |
1650 blue display | sureshplaza | Nokia Hardware & Hardware Repair | 2 | 07-16-2008 16:55 |
c60 blue display flash is ok phone dead | alb97 | Siemens Hardware Repair Area | 3 | 04-17-2006 10:55 |
