12-27-2009, 11:58 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: India Age: 37
Member: 145082 Status: Offline Thanks Meter: 798 | nokia 1650 charging ways required urgently urgently have checked the fuse but the phone is not charging when the fuse is removed the charging pins shows proper voltage 6.2v if the fuse is put back it shows 2.20v what can be done thanks wbr |
12-27-2009, 12:25 | #3 (permalink) |
Member: 145082 Status: Offline Thanks Meter: 798 | could u help me with a pic have removed the ic even though not charging the phone is not giving "not charging" it do not show anything when the charger is connected !!! help me up |
12-27-2009, 12:29 | #4 (permalink) |
Registered User Join Date: Nov 2008 Location: tepian brantas,east java.Ina
Member: 892591 Status: Offline Thanks Meter: 42 | http://i46.tinypic.com/2j4cawj.jpg on the red mark from connector charger ,, after it, throug to Uem,, |
The Following User Says Thank You to t.technic For This Useful Post: |
12-27-2009, 12:45 | #8 (permalink) |
Member: 892591 Status: Offline Thanks Meter: 42 | remove ic, the ic is limiter over voltage,it will solved your problem about your dropped volt, after that if you wont safe, change it with dioda from 3100 or the others type with same fungtion,, dont worry. try its,, |
2310 charging ways please urgent | meeru | Nokia Hardware & Hardware Repair | 6 | 07-27-2013 11:02 |
Nokia 1650 Complete Hardware Repair Solution Nokia 1650 Sim ways Nokia 1650 buzzer | ..::akkas_sarkar::.. | Nokia Hardware & Hardware Repair | 4 | 05-10-2010 09:54 |
urgent Nokia 6630 charging ways short help please | pian_aneurysm | Nokia Hardware & Hardware Repair | 0 | 06-23-2009 02:35 |
B100 charging schematics required urgent | asif_ae | Samsung Hardware Repair | 1 | 05-18-2009 12:41 |
Nokia 1650 charging problem | littletani | Nokia Hardware & Hardware Repair | 7 | 02-20-2009 08:04 |
