nokia 1650 insert sim problem my friend i have a nokia 1650 its showing insert sim i heat the sim ic but problem is not solve any idea what can i do |
search in forum Use Search Botten |
i also serach in the forum but not find any good soluction i am confused pls help meeeeeee |
i am wating for ans my friends |
pl try 2 change the sim which ic support for 1600 your pro will 100% best of luck |
1 Attachment(s) 1200 1208 1209 1650 sim ic location is same try this jumperS IN R2700 |
Thank's to makkah mobile...... |
my friends i make the jumper as on the pic in sim ic but problem is not solve and i confused what is mean in the pic "these two pins" |
first replace sim esd filter , if problem not solved check vsim voltage if voltage missing then fault is in uem good luck |
where i can check vsim voltage |
remove sim ic then make jumber same 1600 1110 100% ok |
my friend i also try this soluction but problem is still |
Your problem is 100% Solved Here. Just Check this out. Nokia 1650 Insert Sim Ways Mobile Repairing Picture Help If you like the post Please HIT THANKS BUTTON |
