Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Hardware & Hardware-Repair Area
Nokia Hardware & Hardware-Repair Area all what you need for Hardware Repairing for Nokia Phones. Before writing any thread here try to check the Frequently Asked Questions Section.
Old 07-29-2008, 12:27   #1 (permalink)
Member: 301177
nokia 1650 insert sim problem
my friend i have a nokia 1650 its showing insert sim i heat the sim ic but problem is not solve any idea what can i do
The Following 3 Users Say Thank You to ameho0102 For This Useful Post:
Old 07-29-2008, 12:34   #2 (permalink)
nasirkhan007's Avatar
Member: 553445
Sonork: 100.1585581
search in forum Use Search Botten
The Following 4 Users Say Thank You to nasirkhan007 For This Useful Post:
Old 07-29-2008, 12:39   #3 (permalink)
Member: 301177
i also serach in the forum but not find any good soluction i am confused pls help meeeeeee
Old 07-30-2008, 08:21   #4 (permalink)
Member: 301177
i am wating for ans my friends
Old 07-30-2008, 08:49   #5 (permalink)
Member: 626855
pl try 2 change the sim which ic support for 1600 your pro will 100% best of luck
The Following 2 Users Say Thank You to lavkey For This Useful Post:
Old 07-30-2008, 09:08   #6 (permalink)
makkah mobile's Avatar
Member: 226363
Sonork: 03--4899925
1200 1208 1209 1650 sim ic location is same try this jumperS IN R2700
The Following 16 Users Say Thank You to makkah mobile For This Useful Post:
Old 07-30-2008, 09:53   #7 (permalink)
tutu1982's Avatar
Member: 193430
Sonork: tutul.ahmed@yahoo.com
Thank's to makkah mobile......
Old 07-30-2008, 11:21   #8 (permalink)
Member: 301177
my friends i make the jumper as on the pic in sim ic but problem is not solve
and i confused what is mean in the pic "these two pins"
Old 07-30-2008, 13:52   #9 (permalink)
Member: 821378
pls help me 1650 insert sim
Old 07-31-2008, 06:58   #10 (permalink)
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
first replace sim esd filter , if problem not solved check vsim voltage if voltage missing then fault is in uem
good luck
Old 07-31-2008, 12:39   #11 (permalink)
Member: 301177
where i can check vsim voltage
Old 07-31-2008, 12:53   #12 (permalink)
Member: 571154
remove sim ic then make jumber same 1600 1110 100% ok
The Following User Says Thank You to fizalelectronic For This Useful Post:
Old 07-31-2008, 14:14   #13 (permalink)
Member: 301177
my friend i also try this soluction but problem is still
Old 07-31-2008, 16:29   #14 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
then problem in uem reball uem...
The Following User Says Thank You to digitized For This Useful Post:
Old 01-05-2009, 15:40   #15 (permalink)
saqib_islam's Avatar
Member: 446881
Your problem is 100% Solved Here. Just Check this out.
Nokia 1650 Insert Sim Ways
Mobile Repairing Picture Help
If you like the post Please HIT THANKS BUTTON
The Following 14 Users Say Thank You to saqib_islam For This Useful Post:
Nokia 1650 insert sim d.jain Nokia Hardware & Hardware-Repair Area 6 11-18-2009 07:26
Nokia 1650 insert sim d.jain Nokia Hardware & Hardware-Repair Area 0 11-15-2009 13:20
1650 insert sim problem RASHED SAM Nokia Hardware & Hardware-Repair Area 1 09-12-2009 15:46
NOKIA 1650 insert sim frfaisal Nokia Hardware & Hardware-Repair Area 2 09-10-2009 17:05
Page generated in 0.34223 seconds with 12 queries
