Old 05-19-2013, 14:03   #1 (permalink)
Member: 1259590
Thanks Meter: 48
Arrow nokia 206/2060 pinout 100000% working
rasel alnuqtha
post solution 10000000000000000000%working
The Following 6 Users Say Thank You to rasel786 For This Useful Post:
Old 03-07-2014, 06:49   #2 (permalink)
narayan pathak's Avatar
Member: 1864020
Sonork: 100.1624750
Thanks Meter: 44
Last edited by narayan pathak; 03-07-2014 at 06:51. Reason: nokia 206 pinout solution .......................
The Following User Says Thank You to narayan pathak For This Useful Post:
Old 03-28-2014, 13:33   #3 (permalink)
Member: 321632
Thanks Meter: 21
Originally Posted by narayan pathak View Post
Good pinout, 100% working
The Following User Says Thank You to mafolk For This Useful Post:
Old 04-22-2014, 07:43   #4 (permalink)
.::Mustafa::.'s Avatar
Member: 1857951
Sonork: 100.1638512
Thanks Meter: 261
brother good work this pin outs working 100% ok
The Following User Says Thank You to .::Mustafa::. For This Useful Post:
Old 05-13-2014, 07:22   #5 (permalink)
Member: 241650
Thanks Meter: 71
Tested. Nice illustration. Thank you.
The Following User Says Thank You to ruvan For This Useful Post:
Old 05-13-2014, 08:16   #6 (permalink)
sunil8488's Avatar
Member: 1233475
Sonork: 100.1615564
Thanks Meter: 54
right solution 100% working
The Following User Says Thank You to sunil8488 For This Useful Post:
Old 08-11-2014, 13:50   #7 (permalink)
yudi_ar's Avatar
Member: 2155369
Thanks Meter: 706
THANK YOU SIR...........!!!!!!!!!!!!!
May *** give you bless, aamiin...
Number of Image Files: 3
Processing Image File :
rm872__04.51.mcusw
rm872__04.51.ppm_s1
rm872__04.51.image_s1_059Q8F0_059T3S1_287_01
AUTO SELECTED DEAD USB FLASHING...
If Phone Booting does not Start in 5 Seconds,
Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
Infineon USB Boot: F00A1FB300020303010100FF
Sending PBL...
PBL Successfully Sent...
Sending SBL...
SBL Successfully Sent...
Setting Transmission Speed Done...
Flash Chip Manufacturer: Intel Electronics Corp.
Flash Boot Successful...
Unique Data: 12201410AF0A282F
Original Product Code: 059Q4L3
Reading : CCC... OK!
Reading : HWC... OK!
Reading : NPC... OK!
RPL Backup was Successful...
Plain RPL saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\356703054385348\3567030543853 48_193933.rpl
Certificate Block Saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\356703054385348\3567030543853 48_CERTIFICATE_B3DCDC82.bin
PM Block Saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\356703054385348\3567030543853 48_PMM_PROT_6601ADA2.bin
Security Code: 12345
Data Sections : 04
Current File : rm872__04.51.mcusw
Compile Name: rm872__04.51.mcusw_ebl_psi.fls
Image Type : Main Firmware
Data Size : 26480008 Bytes
Sending Certificate Block
FIRMWARE Certificate Block Sent Successfully...
Processing Section 01
FIRMWARE Erase Block: 0x40000000~0x4001FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 131072 bytes
Data Checksum: AFC6
Uploading Data Blocks to phone...
Block Write Successful...
FIRMWARE Data Blocks uploaded to phone...
Processing Section 02
FIRMWARE Erase Block: 0x40040000~0x4005FFFE
Start Erasing...
Block Erase Done...
Data Checksum: 7A66
Processing Section 03
FIRMWARE Erase Block: 0x40060000~0x4015FFFE
Start Erasing...
Block Erase Done...
Data Size: 1048576 bytes
Data Checksum: 4314
Processing Section 04
FIRMWARE Erase Block: 0x40280000~0x41A7FFFE
Start Erasing...
Block Erase Done...
Data Size: 25165824 bytes
Data Checksum: 7958
Processing Section 05
FIRMWARE Erase Block: 0x43E20000~0x43E5FFFE
Start Erasing...
Block Erase Done...
Data Verification Successful...
Data Sections : 01
Current File : rm872__04.51.ppm_s1
Compile Name: package_s1.ppm_ebl_psi.fls
Image Type : PPM Image
Data Size : 5919132 Bytes
PPM Certificate Block Sent Successfully...
PPM Erase Block: 0x41A80000~0x420FFFFE
Start Erasing...
Block Erase Done...
Data Size: 5915788 bytes
Data Checksum: 45A4
PPM Data Blocks uploaded to phone...
Data Sections : 01
Current File : rm872__04.51.image_s1_059Q8F0_059T3S1_287_01
Compile Name: rm872__04.51.image_s1_059Q8F0_059T3S1_287_01.fls
Image Type : CONTENT Package
Data Size : 16649488 Bytes
CONTENT Certificate Block Sent Successfully...
CONTENT Erase Block: 0x42100000~0x43E1FFFE
Start Erasing...
Block Erase Done...
Data Size: 16646144 bytes
Data Checksum: E5EC
CONTENT Data Blocks uploaded to phone...
CONTENT Erase Block: 0x43E60000~0x43F3FFFE
Start Erasing...
Block Erase Done...
Total Flashing Time (Erase + Flashing) : 00:08:30
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
Scanning USB Ports...
Basic Phone Information
MCU Version: V 04.51 31-05-13 RM-872 (c) Nokia
IMEI Plain : 356703054385348
IMEI Spare : A356703054385340
IMEI SV : 33567030543853410F
IMEI (2nd) : 356703054385355
IMEI Spare : A356703054385350
IMEI SV : 33567030543853510F
Phone Model: K 206
Category : Entry
Phone Type : RM-872
Extended Phone Information
Product Serial Number: A776DABBI
Product Code : 059Q4L3
Module Code : 0205283
Basic Production Code: 059P6H2
Long Production SN : 0
PPM SW Version : V 04.51 31-05-13 RM-872 (c) Nokia S1
BT MCM Version : 19b5-22012
MCU SW Version : V 04.51 31-05-13 RM-872 (c) Nokia
HW Version : 2300
RFIC Version : 68
LCD Version : TPO
Content Pack Version : Content: s1_059Q8F0 V 04.51 31-05-13 RM-872 (c) Nokia
Bluetooth ID : C81:0B:C6:78:FF
CS Type : GSM900, GSM1800
********** SIMLOCK INFO **********
CONFIG_DATA : 0010100000000000
PROFILE_BITS : 800000000004000B
ASIC : 11
PROVIDER : Default Test Operator
LOCK COUNTERS: KEYPRESS 0/3, FBUS 0/10
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
SIMLOCK_TYPE : PA_SIMLOC30 (20-digit NCK)
SIMLOCK_TEST : PASSED
SECURITY_TEST : PASSED
SECURITY_CODE : 12345
PHONE_MODE : TEST
Dynamic Camera Configuration
DCC ID : 01029704
DCC Ver: 008013
Status : OK
Selected VPL File:
RM872_059T3S1_04.51_005.vpl
Variant Details : RM-872 VAR APAC S1 ID TRI 2GB MAGENTA
Software Version : 04.51
Product Type : RM-872
Product Code : 059T3S1
Variant Version : 005
FACTORY SET TO : Full Factory Set
OK
FACTORY SET TO : User Data
OK
FACTORY SET TO : Leave Factory
OK
FACTORY SET TO : Service Center
OK
FACTORY SET TO : Software Upgrade
OK
FACTORY SET TO : Production Tune
OK
RESET LIFE TIMER TO : 0000:00
OK
The Following 3 Users Say Thank You to yudi_ar For This Useful Post:
Old 08-29-2014, 08:24   #8 (permalink)
Thanks Meter: 4,183
Good pinout, 100% working........................................... .....
Old 11-08-2014, 04:07   #9 (permalink)
Member: 1643167
how to unlock my cellphone nokia model 206.1
IMEI 354126053336587
Old 11-12-2014, 06:00   #10 (permalink)
Member: 2290033
nice Post but which box is support this method please help me . . . . . ..
Old 09-04-2015, 18:36   #11 (permalink)
Member: 1950101
Sonork: mla
makasi boskuuu izin koleksi yahh
The Following User Says Thank You to shidqhi For This Useful Post:
Old 09-27-2015, 22:18   #12 (permalink)
Member: 508097
thanks friends for helps
Old 09-29-2015, 16:09   #13 (permalink)
sajid8282's Avatar
Member: 2399952
Thanks Meter: 40
help nokia 206.1 error on flashing
Processing Region 5/5
Erase , Start : 0x43E20000 , Len : 0x00040000
[ERR_hReqFlashEraseStart] : 8201410040000000
Error...
-> Check cable, flashfile, try again from this file
Old 10-04-2015, 15:46   #14 (permalink)
ABUU YUUNUS's Avatar
Member: 319112
Thanks Meter: 164
It's better to get the cable in order to save time and even prevent possible damage to the pcb.
Old 10-07-2015, 16:08   #15 (permalink)
Member: 1592509
Thanks Meter: 4
206 Low net problem any solution?
Page generated in 0.27728 seconds with 9 queries
