Old 10-04-2014, 07:17   #1 (permalink)
mahzra azra's Avatar
Member: 1722956
Sonork: mybestfriend.adeel
Thanks Meter: 305
nokia 206 display light problem ..extra strange problem >>>>>>>>>>>
look it-----
Old 10-04-2014, 08:22   #2 (permalink)
Member: 2138570
Sonork: 100.1611495
Thanks Meter: 301
brother do it my way
it will be ok 100000000%
Old 10-04-2014, 08:35   #3 (permalink)
Member: 1722956
Thanks Meter: 305
bro thanks for hardwork but i do not want any jugaad<short cut>.
i knew it very well but i need proper solution of this problem.why it cannot solve as normal ways?
<i do not do any repairing in display, i need reason of his fault>.
again thanks for your wasting time
connect me on yahoo-- [email protected]
Old 10-06-2014, 11:07   #4 (permalink)
laxmi kamlesh's Avatar
Member: 1873645
Thanks Meter: 977
yes this problem solve not possible in normal ways.
bcz in transistor 1 point must need gnd. like in bellow image.but this is show reading/volts.
so can't say it will be possible.
need to change power ic.
Old 10-07-2014, 08:30   #5 (permalink)
Member: 1722956
Thanks Meter: 305
yes bro ,you are right.
i said same in my posting.no any solution for light for this problem from normal ways.
thanks for reply.
Old 11-21-2014, 17:05   #6 (permalink)
Member: 532988
Thanks Meter: 2
yes brother my nokia 206 same problem any other solution
Old 11-22-2014, 12:14   #7 (permalink)
Member: 1722956
Thanks Meter: 305
1st change power and flash both ic.
2nd apply upper solution for light .
no 3rd option.
Old 01-14-2015, 13:09   #8 (permalink)
blacky199's Avatar
Member: 2030192
Thanks Meter: 1,334
Arrow
thank you for this good post it helped me to recover lcd light
Old 11-10-2015, 14:44   #9 (permalink)
PAKFAN's Avatar
Member: 424731
Sonork: 100.1669530
Thanks Meter: 18
mahzra azra your tarck ok but light dim and Ismail khan1978 your post ok and hard work but my set is ok thankyou sirrrrr and good post
The Following User Says Thank You to PAKFAN For This Useful Post:
Old 11-12-2015, 06:42   #10 (permalink)
Member: 1722956
Thanks Meter: 305
bro if you got dim light problem,for it change coil only from other board. i am sure,dim light problem solved.
The Following User Says Thank You to mahzra azra For This Useful Post:
Page generated in 0.20529 seconds with 8 queries
