Old 05-24-2005, 19:54   #1 (permalink)
Member: 82155
Thanks Meter: 33
nokia 2100 battery discharging problem
it runs down immediatey u are taking a call or making a call any solution
Old 05-25-2005, 04:18   #2 (permalink)
watari31's Avatar
Member: 141262
Thanks Meter: 348
check!!!
check ur phone battery supply if slightly shorted.. test point use multitester use ohms 1x... + to + and - to - output has a continuity... then + to - and
- to +... output: if there a continuity only means phone is shorted and
if it has no continuity it only means it is not shorted. then u have to replaced your battery...
here a tip if ur battery is weak...
if your battery indicates low batt.. just charge your battery 3hrs straight.. then after 3hrs unplugged it then use it for call and txt.. if ur battery last for 1 to 2 days your battery still ok.. but doesn't last for a day.. u have to replaced ur battery...
Old 05-25-2005, 08:12   #3 (permalink)
SCOOTER_R's Avatar
Member: 89571
Thanks Meter: 16
change the PF "pfo103"
Old 05-25-2005, 12:26   #4 (permalink)
Member: 132881
Thanks Meter: 105
i think its pf too better known as power amp
Nokia 2100 Contact Service Problem sultanpk Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 34 01-22-2010 13:46
nokia 1600 battery discharge after 1 hour gsm_cdma_ufs Nokia Hardware & Hardware Repair 10 04-12-2009 23:17
Nokia 1100 Quick Discharge problem hhhhhh111111 Nokia Hardware & Hardware Repair 4 04-07-2008 14:41
2100 battery discharge mozie Nokia Hardware & Hardware Repair 9 07-08-2004 10:18
Nokia 2100 Missed Calls problem solved 100% Tanvir Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 12-01-2003 21:26
Page generated in 0.81789 seconds with 9 queries
