Old 05-22-2006, 20:50   #1 (permalink)
Member: 93059
Post Nokia 2100 Contact Service
Hi,
I got one Nokia 2100 by a customer which always shows Contact Service.Checked it and flashed but its not a software problem so how can I repair it by Hardware.Any Pics or Hints.And
Another Nokia 3310 which sometimes charges and sometimes says reconnect charger or can't charge.Checked pin,its all Ok. What can be the reason.
Thanks In Advance
Regards
Old 05-23-2006, 05:18   #2 (permalink)
Member: 279575
for 2100 .......at first change cobba and upgrade the phone if not change flash ic. contact service appears from many other areas but first you have to do this section repaired.......from himadri kolkata india mob-no---9831180436
Old 05-23-2006, 05:22   #3 (permalink)
..:MumbaiGsm:..'s Avatar
Member: 205738
Thanks Meter: 129
2100 : if u r sure its not software problem then reball or replace Audio IC
(Cobba).........
OR
flash it by Twister and rebuild IMEI then set faid-inti sim-full factory
ok..........100% work
3310 : replace charging connector and for more help search forum ...................
Old 05-23-2006, 05:49   #4 (permalink)
gokul2005's Avatar
Member: 169384
Thanks Meter: 108
nokia2100
flash in UFS with PMM. if same problem check info an see the cobba sereal it shows 0000000...... change the cobba.
Old 05-23-2006, 08:30   #5 (permalink)
W4r10rD's Avatar
Member: 183043
Thanks Meter: 68
with the 3310 you must bridge two caps at charging ic and it will work 100%
Old 05-23-2006, 15:31   #6 (permalink)
Member: 211283
Thanks Meter: 6
Originally Posted by balouch
Hi,
Thanks In Advance
Regards
only cobba change and than write flash
Old 05-23-2006, 17:21   #7 (permalink)
Member: 211422
hi,
where i can find the software that works to reflash/read flash on to Nokia 2100. I use some like DCT3_2100_Flasher and 3610 Nasiryan, or geoflash or kNok-Phoenix_suport_2100_3610 but the phone cannot inialize. I think the correct fia files is missing to reconigze the phone. Any solutions? please without box, i haven't -* only flasher.
tx
Old 06-03-2006, 05:58   #8 (permalink)
..::My3gtech::..'s Avatar
Member: 158032
Thanks Meter: 331
Hi
Hi,
Thanks In Advance
Regards
Friend just heat on audio ic ( cobban ) then check if not then replace the cobba ic and then reflash them and all should be ok and about pic just go to
nokia hardware and repair area and look how to solve this problem.And if u dont find then pm to me i will send it to u thank's and take care.
Omairbutt786
Old 06-03-2006, 13:34   #9 (permalink)
Member: 273997
Thanks Meter: 8
Hi,
Thanks In Advance
Regards
first flash 2100 with pmm if same problem then change cobba 100%working in 3310 there is a small registance on the right side of charging ic change
Old 06-04-2006, 18:49   #10 (permalink)
Member: 62321
Thanks Meter: 35
1st flash it with 2 m.b flash file if still change cobba
nokia 2100 contact service --still problem after flash--- crossings Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 49 11-11-2007 16:06
help nokia 2100 contact service ramoon20 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 10-29-2004 06:52
nokia 2100 - contact service imran_k Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 10-23-2004 11:06
Nokia 2100 contact service Natali Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 09-03-2004 08:24
Nokia 2100 Contact service thunoy Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 09-10-2003 09:46
Page generated in 0.34039 seconds with 8 queries
