12-03-2013, 19:35 | #1 (permalink) |
Junior Member Join Date: Dec 2013
Member: 2077803 Status: Offline Thanks Meter: 0 | Nokia 2100 network only when charging Can anyone help? Thank you. |
12-03-2013, 23:23 | #2 (permalink) |
No Life Poster Join Date: Jul 2005 Location: karachi
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | In charging mode, u can make call or not when signal is stable? If u remove charger signal immediately gone ,and when u search network manually wat it show on screen ? |
12-04-2013, 22:31 | #3 (permalink) |
Member: 2077803 Status: Offline Thanks Meter: 0 | Hi brother, today the signal is good without charger and when trying to search for network it shows (after 8 seconds) only my operator and here in my country there are three operator so i think the problem still exist but in other form.. sometimes the signal disappear but for few minutes. Thank YOU |
12-05-2013, 02:08 | #4 (permalink) |
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | Ok if u run ur own shop than follow steps change middle casing bcoz in some case it cause signal problem if u already try above than u have to change antenna switch or make jumper (jumper trick already posted many times in forum) just use search option for 2100 antena switch |
12-05-2013, 02:08 | #5 (permalink) |
The Following User Says Thank You to HUM For This Useful Post: |
12-17-2013, 23:25 | #6 (permalink) | |
Member: 2077803 Status: Offline Thanks Meter: 0 | Quote:
Thanks anyway | |
