nokia 2220s contact service nokia 2220s contact service |
1st scan mexky software ok 2 re hot cpu and Cline full bored..... |
MCU SW : V 10.25 30-07-10 RM-590 (c) Nokia PPM SW : V 10.25 30-07-10 RM-590 (c) Nokia M_F Product : Nokia 2220s Prd.Code: 0590597 Bpr.Code: 0582851 Prod.Sn : IRI240906 HW Vers : 2000 UEM : 1328 UPP : 12648 [3168] RFIC Ver: 0500 DSP Vers: ICPR72_09w52_U LCD Type: SUEZ CAM Prim: GR0103D1012601022E05_001007 IMEI : 356991-04-386837-1 SL Conf : 001-01-00000000000 SL Prof : 000000000003000-B SL Var : 00553569910438683700 SL Aux : 000B5555 HW Sig : 525E104FE68E38F3 Box Id : FFFFFFFFFFFFFFFF BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN Provider: GSM Test Equipment |
#1 (permalink) gee_asad Crazy Poster Join Date: Oct 2011 Posts: 58 Member: 16754 bor..UEM IC Repeir contact service Repeir |
no same........................................... |
1 Attachment(s) Quote:
what wey................... |
MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 4] - C086CBB7 Driver: NMWCD, ver: 7.1.32.73 Module ver: 1.0.0.17602(14-06-2011), Library ver: 1.0.0.13703(05-01-2012) Processing MCU file: 309BC0DD_rm635__10.60.mcusw [BB5,BB5 ALGORITHM] size: 17.99 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2673BC70 CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] CMT EM0 ID: 00000296 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 081002057016565035148EC2C7A8FB8FA350343D CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID: 273F6D55DFAAF68F Flashing CMT Update Server Data, ULO: 0x3900 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, UPDAPP: 0x49480 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, PASUBTOC: 0x57AC0 bytes Update Server code succesfully sent to phone. Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 19D09CA Verifying communication to device OK. Erase size: 21 MB CMT NOR area [00000000-000006BF] erased in 0.703 s CMT NOR area [000006C0-0001FFFF] erased in 0.687 s CMT NOR area [00040000-000BFFFF] erased in 2.594 s CMT NOR area [000C0000-0013FFFF] erased in 2.578 s CMT NOR area [00140000-0137FFFF] erased in 1 min 36.203 s CMT NOR area [01380000-0151FFFF] erased in 8.844 s Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: C6B9354E81AC464DED33FC7B90295086150F4539 (RAP Certificate v1 246) sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent Programming completed in 1 min 1.438 s Processing PPM file: 787A8770_rm635__10.60.ppm_uab [BB5,BB5 ALGORITHM] size: 3.18 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 8.62 MB CMT NOR area [01520000-01DBFFFF] erased in 45.031 s Flash programming ... Programming completed in 11.000 s Processing CNT file: D5209ADD_rm635__10.60_007.image_uab_vivo_br_v3_990 43 [BB5,BB5 ALGORITHM] page size: 128 K size: 7.51 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 34 MB CMT NOR area [01DC0000-0215FFFF] erased in 26.812 s CMT NOR area [02160000-03FBFFFF] erased in 3 min 52.188 s Flash programming ... Programming completed in 25.156 s Total time for flashing process(boot+erase+write) was 9 min 6.907 s Waiting for device boot up ... Device found: nmwcdc\Nokia 2690 USB Phonet, PORT_ID: 37E1B832 Verifying communication to device OK. Phone Type: RM-635 (Nokia 2690) SW Version: V 10.60 10-06-10 RM-635 (c) Nokia Imei plain: 35486004998832-1 Product Code: 0592076 Battery voltage: 3794 mV, current: 65 mA Language Pack: - not available. Detected as PA_SL3 phone. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 354860049988321 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Market items is empty, please select the correct products path ! Nokia USB ROM disconnected. |
I decided my 2220 recording a FULL PM and then I click Unlock using Universalbox 100%. |
