Old 09-19-2016, 08:52   #1 (permalink)
Member: 1630066
Sonork: 520074
Thanks Meter: 215
Nokia 225 restart on call
I have nokia 225 rm-1011 it restarts when i dial any no and press yeh
also when i receive a call
i have full flashed all versions but same
any solution
The Following User Says Thank You to ilyasrao For This Useful Post:
Old 09-27-2016, 04:50   #2 (permalink)
Member: 1278793
Thanks Meter: 68
First insert handfree and make a call if phone didnot off or restart change the earpice
The Following 3 Users Say Thank You to melotech For This Useful Post:
Old 10-08-2016, 13:04   #3 (permalink)
gul551's Avatar
Member: 565096
Thanks Meter: 1,540
change small speaker of nokia 225 i think u r problem will solve
Old 12-06-2016, 12:47   #4 (permalink)
Member: 2477331
Sonork: 100.1676088
Thanks Meter: 29
any solution???
Old 12-06-2016, 15:35   #5 (permalink)
Member: 2657685
hi perform a factory reset sometime configuration problem may do the trick
Old 01-06-2017, 13:22   #6 (permalink)
Member: 1705566
Thanks Meter: 9
pls hedphone insert.....................remove................. ..... problem,,,,,,,,,solve
The Following User Says Thank You to vimy For This Useful Post:
Old 01-11-2017, 20:09   #7 (permalink)
Member: 1982719
Thanks Meter: 2
SIR..
write PM...it could b solve ur problem..
Old 06-17-2017, 10:54   #8 (permalink)
Member: 2362249
Thanks Meter: 14
insert headhpone when remove same problem
any perfect solution please
Old 06-17-2017, 14:52   #9 (permalink)
Member: 1630066
Sonork: 520074
Thanks Meter: 215
problem solved with clean the mothorboard with thinner
Old 10-17-2017, 15:20   #10 (permalink)
Member: 2327131
Just check earpiece if it touch ground then it will restarts check it properly ur problem will b solved 100%
Old 06-21-2018, 11:32   #11 (permalink)
Member: 2822758
sir give any solution...
Old 09-21-2020, 17:26   #12 (permalink)
Member: 2860321
earpice
100%
Old 09-22-2020, 05:47   #13 (permalink)
Member: 253496
Thanks Meter: 4
change original ear speaker
Page generated in 0.17580 seconds with 8 queries
