11-18-2006, 18:27 | #1 (permalink) |
Junior Member Join Date: Jul 2006
Member: 306330 Status: Offline Thanks Meter: 1 | Nokia 2300 switches off automatically..... i m having a nokia 2300 which switches off automatically after around 5 seconds.....battery is original company one and fully charged....is there any solution for this prob??? regards RZQ |
11-19-2006, 12:30 | #5 (permalink) |
Member: 306330 Status: Offline Thanks Meter: 1 | i switch on the phone....sumtimes b4 getting network it switches off nd sumtimes just after getting the network.... how to full erase without starting nd how to flash??what uem?? |
11-19-2006, 13:40 | #6 (permalink) |
Freak Poster Join Date: Oct 2005 Location: perth aust.
Member: 188959 Status: Offline Thanks Meter: 7 | DON'T replace the PA or flash anything until... Firstcheck if the handset is fluid damaged.Look up 1amigos post on repairing fluid damaged phones, and follow instructions. I rarely see a handset turn itself off due to a corrupted flash, and a PA prob is reasonably easy to diagnose.PA's strip battery power very quickly, so plug handset to charger ,and make a phone call.If the phone doesn't turn off, or battery doesn't discharge, then the battery is at fault.If the handset clips, and gives a low battery warning ,even though it is on charge , then the PA is the culprit. If unit just turns off ,with no warning at all, then 99% fluid damaged. If you have a decent multimeter, connect to pos /neg terms on battery, while connected to phone, and turn unit on /off repeatedly.Measure boot up and idle voltages. If idle V is above 600 ma, you have a short somewhere caused by probable fluid damage. If you have a power suppply, connect to phone, set at 3.6 V , turn handest on.The PS will tell you how much it is drawing.Refer to previous voltage measurements for results. Hope this helps... |
Nokia 2626 switch off automatically | dey mobiles | Nokia Hardware & Hardware Repair | 1 | 11-01-2009 15:10 |
Nokia 1110 Switch Off Automatically in Standby Mode | jalesar | Nokia Hardware & Hardware Repair | 2 | 04-18-2008 17:06 |
Nokia 2300 Switching Off After A Minute | toptech | Nokia Hardware & Hardware Repair | 0 | 03-06-2008 11:06 |
nokia 2300 switching off. | de brain box | Nokia Hardware & Hardware Repair | 2 | 08-06-2006 19:54 |
Nokia 2300 switch Off | balouch | Nokia Hardware & Hardware Repair | 4 | 12-29-2004 09:01 |
