03-03-2009, 09:08 | #7 (permalink) |
Freak Poster Join Date: Apr 2007 Location: Around The World
Member: 482670 Status: Offline Thanks Meter: 125 | 1st=if the set was not water damage ,then u just nid change the led ,i was done many set b4 is just the led spoil..normaly is 95% can done it, if still cant then change light ic , if still cant , that means is water damage set, then u just folow the solution on bro "pathfinder", 100% work if u do that 3 checking ways , good luck =) |
The Following User Says Thank You to Brother Hui For This Useful Post: |
03-03-2009, 11:03 | #8 (permalink) |
Major Poster Join Date: Jan 2009
Member: 945549 Status: Offline Sonork: [email protected] Thanks Meter: 6 | Bro first change led, then ic finally check+b,if three conditions not solved then you may try to replace regulator post me your reply |
03-13-2010, 16:55 | #12 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Punjab India
Member: 687144 Status: Offline Sonork: 1614780 Thanks Meter: 228 | contect me [email protected] i will help u |
03-20-2010, 09:19 | #13 (permalink) |
No Life Poster Join Date: Apr 2002 Location: The Green Mile
Member: 11325 Status: Offline Thanks Meter: 266 | can anyone show which is the light IC that is being referred to pls? thanks |
The Following User Says Thank You to Burnt Cobba For This Useful Post: |
nokia 1208 light problem plz | WHED | Nokia Hardware & Hardware Repair | 12 | 03-31-2012 04:31 |
Whats the perfect solution for 1110,1600,6030,2310 LIght Problem | sharaz191 | Nokia Hardware & Hardware Repair | 7 | 01-08-2011 08:08 |
2310 light problem | segun01 | Nokia Hardware & Hardware Repair | 9 | 08-31-2010 11:27 |
2310 light problem | RaviJain | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 08-31-2010 11:22 |
nokia 2310 light problem plz | WHED | Nokia Hardware & Hardware Repair | 3 | 03-03-2009 08:45 |
