Old 06-19-2010, 09:21   #1 (permalink)
imran zafar's Avatar
Member: 328187
Thanks Meter: 1,687
nokia 2330-2323 auto shutdown solution''''by ''cel_phon
nokia 2330 auto shutdown solution
apply this jumper with a simple diode
The Following 197 Users Say Thank You to imran zafar For This Useful Post:
Old 06-20-2010, 05:43   #2 (permalink)
Member: 328187
Thanks Meter: 1,687
some one try this solution????
The Following 3 Users Say Thank You to imran zafar For This Useful Post:
Old 06-20-2010, 12:18   #3 (permalink)
Member: 972454
Thanks Meter: 6
which diode is use this solution for better result
The Following User Says Thank You to bajji For This Useful Post:
Old 06-20-2010, 13:59   #4 (permalink)
Registered User
BouRRi_GSM's Avatar
Member: 111457
Thanks Meter: 967
theorically, what's the need of this diode?
br
The Following 28 Users Say Thank You to BouRRi_GSM For This Useful Post:
Old 06-20-2010, 14:03   #5 (permalink)
Member: 328187
Thanks Meter: 1,687
u can use this type diode as shown in pic
The Following 65 Users Say Thank You to imran zafar For This Useful Post:
Old 06-20-2010, 14:29   #6 (permalink)
Member: 328187
Thanks Meter: 1,687
actually power IC was not producing (vio 1.8v) properly
then i use a substitute power(v flash 2.8v) on vio battery
but vio and vflash r not in same values.....and a diode
can easily recover this voltage gape ......if we dont use
a diode here and make jumper directly here ....then....
it will more pressure on ...CPU ... the using of diode is better
The Following 8 Users Say Thank You to imran zafar For This Useful Post:
Old 06-21-2010, 06:44   #7 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,469
yes yes diode using better otherways after few days phone UPP going to damage
The Following User Says Thank You to SHIJILFONOTLY For This Useful Post:
Old 06-21-2010, 07:17   #8 (permalink)
Member: 235616
Thanks Meter: 67
i have 5030 its auto restart.i full erase full flash write pm full unlock but no ok.Then i change UEM and CPU make rpl but not ok any body help me. Are apply this Diode for 5030 how can i used this. Thanks
The Following 3 Users Say Thank You to asims For This Useful Post:
Old 06-21-2010, 07:30   #9 (permalink)
Member: 328187
Thanks Meter: 1,687
change 26MHz crystal......clean lcd points if water demage
change sim ic......check sim tray......finely replace ram ic
Old 06-21-2010, 08:37   #10 (permalink)
GSMTURBO's Avatar
Member: 479496
Sonork: 1592751
Thanks Meter: 404
yes diode is better coz vol farwerd not came back so safe for power ic also give corect vol not updown
The Following User Says Thank You to GSMTURBO For This Useful Post:
Old 06-24-2010, 10:17   #11 (permalink)
Steamroller's Avatar
Member: 126197
Thanks Meter: 26
GOOD solution , tested on 2330 and 2680 ! works great ! Thanks'
The Following User Says Thank You to Steamroller For This Useful Post:
Old 06-28-2010, 12:03   #12 (permalink)
Member: 812164
Thanks Meter: 17
i have proper solution for shutdown prob if ani one need contact me [email protected]
Old 06-28-2010, 12:18   #13 (permalink)
Member: 812164
Thanks Meter: 17
The Following 6 Users Say Thank You to mirza_alamgir For This Useful Post:
Old 06-28-2010, 12:21   #14 (permalink)
Member: 812164
Thanks Meter: 17
if prob remains there then flash ur fone with ver 6.75 ur prob 1000000000% ok i try and fix my prob many times
Old 07-10-2010, 08:35   #15 (permalink)
Member: 622934
Thanks Meter: 46
2323 no need diod direct jumpeer..........i am tested.........100%.....
Page generated in 0.25007 seconds with 10 queries
