Old 06-05-2008, 12:14   #1 (permalink)
nilesh_patel717's Avatar
Member: 596791
Thanks Meter: 37
nokia 2600
nokia 2600 some time insert sim coming i chang sim ic make jumper but some time it show insert sim
any solution
Old 06-05-2008, 12:17   #2 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
Before change the sim IC check the Sim connector . . .
Post result.
Old 06-05-2008, 12:18   #3 (permalink)
delchoni's Avatar
Member: 239176
Sonork: 100.1602815
Thanks Meter: 851
chek for conection from batery bsi to phone bsi and post result
Old 06-05-2008, 12:24   #4 (permalink)
vicky kumar's Avatar
Member: 737188
Thanks Meter: 37
check the battery connentor first
then proper way to fit ic
Old 06-05-2008, 13:07   #5 (permalink)
[Shadab_M]'s Avatar
Member: 238812
Sonork: 100.1602669
Thanks Meter: 1,443
Check if it shows Not Charnging when connecting charger.
If it says Not Charging then just Change Battery connector or check BSI Line.
If it shows Charging normally, then problem is with SIM IC or SIM SOCKET.
Check and Post Result.
Br,
Shadab Ahmad
Old 06-05-2008, 13:46   #6 (permalink)
Member: 596791
Thanks Meter: 37
THANKS FOR SUPPORT Problem SOLVE
Old 06-26-2008, 09:58   #7 (permalink)
Member: 575112
Thanks Meter: 62
sir
can u send me the bsi ways with pictures,thanks
Old 06-26-2008, 09:58   #8 (permalink)
Member: 575112
Thanks Meter: 62
from batt where it connects in the board
Old 06-26-2008, 11:48   #9 (permalink)
Member: 580482
any solution
You check the battery connector or change battery............
Old 06-26-2008, 13:36   #10 (permalink)
Member: 792839
Thanks Meter: 1,104
any solution
change the new battery and bettery bin together
Old 07-17-2008, 09:41   #11 (permalink)
Member: 39561
Thanks Meter: 109
do you have diagram for 2600 insert sim?
Old 07-11-2009, 06:31   #12 (permalink)
Crazy Poster
Member: 1042203
Thanks Meter: 46
does any one have 2600 battery connector ways
Old 04-25-2012, 09:53   #13 (permalink)
easir.comilla_e's Avatar
Member: 1488757
Thanks Meter: 98
2600 nokia battery connector bor...try.....agin
23-05-2008 New Nokia Tool - added unlock/relock Nokia 2600, 2630 and others! GSMtricks Multi-box LITE 28 02-02-2010 21:33
Nokia Nokia 2600 keypad not working zakir375 Nokia Hardware & Hardware Repair 2 11-30-2006 22:22
idiot nokias 2600 shows menu with out sim card mobilemafia Nokia Digital Core Technology 4 ( DCT-4 ) 4 02-11-2005 08:10
nokia 2600 don't call masci Nokia Digital Core Technology 4 ( DCT-4 ) 1 11-20-2004 20:28
Page generated in 0.20774 seconds with 11 queries
