nokia 2626 contact service nokia 2626 phone is water damege i am service phone than show contact service plz help me sir |
bro try flash lettest v write good pm file unlock ui setting |
Getting MCU ID Phone didn't answer with TX line low after UEM reset! Causes: 1. put a 27-33 pico capacitor in connector b/w mbus-gnd. 2. UEM damaged -> replace uem. MCU ID: 0xDDDD Failed! Aborting! Done! Phone Restarted... Changing mode...Done! Booting phone... Error sync the phone... Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-291\ Searching for default location of ini... Checking path: \Products\RM-291\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-291\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: D:\NOKIA FLASH FILE\dct4\2626_rm-291_v6.81\rm291__06.81.mcusw PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: D:\NOKIA FLASH FILE\dct4\2626_rm-291_v6.81\rm291__06.81.mcusw PPM Flash file: D:\NOKIA FLASH FILE\dct4\2626_rm-291_v6.81\rm291__06.81.ppm_ej CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: D:\NOKIA FLASH FILE\dct4\2626_rm-291_v6.81\rm291__06.81.mcusw PPM Flash file: D:\NOKIA FLASH FILE\dct4\2626_rm-291_v6.81\rm291__06.81.ppm_ej CNT Flash file: D:\NOKIA FLASH FILE\dct4\2626_rm-291_v6.81\rm291__06.81.image_ej ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Backing up PM Field 208 as RPL... Setting local mode... Reading IMEI... Failed! Aborting! Failed to backup imei... MCU: D:\NOKIA FLASH FILE\dct4\2626_rm-291_v6.81\rm291__06.81.mcusw Booting phone... FAILED ->jaf configuration 2 FAILED ->jaf configuration 1 Phone didn't answer with TX line low after UEM reset! Causes: 1. put a 27-33 pico capacitor in connector b/w mbus-gnd. 2. UEM damaged -> replace uem. MCU ID: 0xDDDD This MCU ID is not supported in chosen flash file... Error booting phone... |
please , replace uem ic . then boot again , if boot ok ,bro use sefl test jaf , post log into pages . i'll help u ! |
