Old 06-03-2008, 17:47   #1 (permalink)
Member: 676100
Sonork: 100.1577777
Thanks Meter: 18
""Nokia 2626 flashing done but not power on - please help me""
I have a Nokia 2626 having problem with contact service, i am also erased and flashed with the version RM-291_dp_42.00_ams_sw-06.80, the flash and the all process done successfully but the set dead now, so please help me.
Thank u in advance
Old 06-03-2008, 19:35   #2 (permalink)
mohammed-anis's Avatar
Member: 751223
Sonork: mobilecenter88
Thanks Meter: 538
cpu damage bro........................
Old 06-03-2008, 19:37   #3 (permalink)
sopnil's Avatar
Member: 528679
Thanks Meter: 268
dear change ppm file then flash only ppm .I think u problem solved ............(if not a hardware problem............)
sopnil
sopniltelecom
Old 06-03-2008, 19:40   #4 (permalink)
makkah mobile's Avatar
Member: 226363
Sonork: 03--4899925
Thanks Meter: 569
after full flash write good pm and then unlock if not sucess then its HW
Old 06-03-2008, 20:28   #5 (permalink)
bathri525's Avatar
Member: 698055
Thanks Meter: 60
Bro Dont Worry .u Cant Write Pm On A Dead Set First Clean U R Board Well Ringsed Then Dont Het But Gently Worm And Fls Pnone With Higher Version Or IF U R Noted The Inital Ver Flash Pnone With Same Mcu Ppm Cnt U R Problem Will Be Solved.
Old 06-16-2008, 08:40   #6 (permalink)
sujan1050's Avatar
Member: 449518
Thanks Meter: 585
after full flash write good pm and then unlock if not sucess then its HW............
Old 06-19-2008, 19:25   #7 (permalink)
Member: 751223
Thanks Meter: 538
change this part problem solved 100%
The Following User Says Thank You to mohammed-anis For This Useful Post:
Old 06-20-2008, 07:46   #8 (permalink)
Member: 774126
Sonork: 100.1645006
Thanks Meter: 42
after flash reheat pcb. particulary uem but gently coz it's glued. it works, i have tried it several times.
Old 08-19-2008, 14:40   #9 (permalink)
guru4gsm's Avatar
Member: 517316
Thanks Meter: 185
Did u Solved ur problem or not..............?
Old 10-13-2008, 07:57   #10 (permalink)
dharmeshslnk's Avatar
Member: 385162
Thanks Meter: 598
no any solution for this problem?
The Following 3 Users Say Thank You to dharmeshslnk For This Useful Post:
2626 flash ok but not power on kadour83 Nokia Hardware & Hardware Repair 4 06-18-2009 19:37
philips 355 (java) flashing done but not power on Satyam321 Multi-Box 4 04-30-2008 07:48
LG KP200 flash done, but not power on!! hungco Multi-Box 3 12-08-2007 06:28
6100 flash ok, but not power on, please help kaholukkk Nokia Hardware & Hardware Repair 3 08-23-2006 17:37
Page generated in 0.17219 seconds with 10 queries
