09-01-2009, 06:37 | #1 (permalink) |
No Life Poster Join Date: Feb 2007 Location: India
Member: 449060 Status: Offline Sonork: 100.1670591 Thanks Meter: 260 | nokia 2626 fleshing MCU ID: 0x3040 FLASH ID0: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.02 Done! Phone Restarted... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Backing up PM Field 208 as RPL... Setting local mode... Failed! Aborting! Failed to backup imei... Flashing Done! Operation took 0 minutes 27 seconds... After flash processing... Waiting for phone to boot... Failed! Aborting! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-291\ Searching for default location of ini... Checking path: \Products\RM-291\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-291\ Scanning ini files... Checking path: \Products\RM-291\ Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-291\ FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-291\rm291__06.80.mcusw PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-291\rm291__06.80.ppm_ic CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-291\rm291__06.80.image_ic ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Arabic,French,Swahili Backup IMEI zone... Setting local mode... Failed! Aborting! Getting MCUID... MCU ID: 0x3040 Reading flash chip detailes... FLASH ID0: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 MCU ID: 0x3040 Boot is ready... Algo is ready... Loader is ready... Erasing area: 01000000 - 01FFFFFF... Done! Backing up PM Field 208 as RPL... Setting local mode... Failed! Aborting! Failed to backup imei... MCU: C:\Program Files\Nokia\Phoenix\Products\RM-291\rm291__06.80.mcusw Booting phone... MCU ID: 0x3040 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Flash ID is 0xE822EC00 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7528; Loader chk: c5 Loader is ready... P-key nokia module version 01.02 MSID: 84A478436A774099B204E9012B MSID decoded: 4F16BAE90054B859A8000000 FAID: EF60813CEAB8D9F8374D02FB Operation took 0 minutes 8 seconds... Erasing... Found 3 interval(s) to erase Erasing area: 01000000 - 0101FFFF... Erasing area: 01020000 - 018DFFFF... Erasing area: 01EE0000 - 01FDFFFF... Operation took 1 minutes 1 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 53 seconds... Restarting MCU... CNT: C:\Program Files\Nokia\Phoenix\Products\RM-291\rm291__06.80.image_ic Booting phone... MCU ID: 0x3040 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0xE822EC00 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7528; Loader chk: c5 Loader is ready... P-key nokia module version 01.02 MSID: 84B33CF32A3179C9CFEBA4218C MSID decoded: D26EBAF10054B859AA000610 FAID: 1FF07BE58C21099D17EDA9CD Operation took 0 minutes 8 seconds... Erasing Content Pack... Found 1 interval(s) to erase Erasing area: 01B80000 - 01EDFFFF... Operation took 0 minutes 21 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 11 seconds... Restarting MCU... Operation took 0 minutes 0 seconds... Extracting Content Pack... Error setting local mode... CP Extract Failed! PPM: C:\Program Files\Nokia\Phoenix\Products\RM-291\rm291__06.80.ppm_ic Booting phone... MCU ID: 0x3040 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0xE822EC00 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7528; Loader chk: 25 Loader is ready... P-key nokia module version 01.02 MSID: 84F7BCB40E07ED4B542680C2C4 MSID decoded: 3E4EBAE90054B859A9000000 FAID: CDD421456D61562CDBE924CD Operation took 0 minutes 8 seconds... Erasing PPM... Found 1 interval(s) to erase Erasing area: 018E0000 - 01B7FFFF... Operation took 0 minutes 16 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 10 seconds... Restarting MCU... Flashing Done! Operation took 4 minutes 18 seconds... After flash processing... Waiting for phone to boot... Failed! Aborting! help |
nokia 1200 flesh light on, after flesh light off mobile off plz help | khan baba34 | Nokia Hardware & Hardware Repair | 1 | 10-14-2009 11:44 |
NOkia 5800 Flesh | munir0410 | Universalbox | 4 | 03-25-2009 23:16 |
Nokia 6030=nokia 2626 | Shakeel_pattoki | HWK | 2 | 06-08-2008 16:11 |
Nokia 6500 fleshing | munir0410 | Universalbox | 2 | 05-11-2008 19:13 |
