Old 04-11-2011, 15:12   #1 (permalink)
Tabrez1's Avatar
Member: 1343156
Thanks Meter: 45
Red face Pleas arjunt help 6120 on vivrate and white light after off
Hi frinds,
I have one set 6120 this set pro set on after on vivrate and white display and off pleas help argent........................Thanks..
Old 04-11-2011, 15:28   #2 (permalink)
nazrul islam's Avatar
Member: 756569
Thanks Meter: 185
You Flash The Set With Latest Flash File ??? Or Not ?? First Flash The Set Then Post Result
The Following User Says Thank You to nazrul islam For This Useful Post:
Old 04-11-2011, 15:32   #3 (permalink)
Member: 582959
Thanks Meter: 9
6120
flash with " _blank_504KB_pmm_10.fpsx " file ,then full flash with 6120 file
The Following User Says Thank You to shamsudheen For This Useful Post:
Old 04-11-2011, 15:35   #4 (permalink)
Tabrez1's Avatar
Member: 1343156
Thanks Meter: 45
Thanks for fast reply..................
Old 04-11-2011, 16:22   #5 (permalink)
Tabrez1's Avatar
Member: 1343156
Thanks Meter: 45
Version from phone: 06.01
Version from file: 07.02
Using device: MTBOX, CR ver: 1.01.0100
Library version: 1.0.0.9019(20-11-2010), 1.0.0.15868(10-03-2011)
Reading phone`s ID ...
FLASHBUS not supported.
Restarting phone ...
Read Certificate failed.
NPC_DATA is empty.
SIMLOCK_DATA saved OK
SIMLOCK_KEY_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
LOCK120_DATA saved OK
BB_DATA saved OK
RPL saved to ".rpl"
Bootstrap failed!
No flash for this massage for MXKEY(mobileEx)
Old 04-12-2011, 10:51   #6 (permalink)
Member: 756569
Thanks Meter: 185
Use HWK...........................
Old 05-11-2011, 12:36   #7 (permalink)
Member: 755660
_blank_504KB_pmm_10.fpsx where is this file?
Old 05-11-2011, 12:51   #8 (permalink)
Member: 755660
select this file in mcu then flash
thts is 1000% work
Old 08-05-2011, 10:50   #9 (permalink)
Member: 755660
5130 2700 5230 etc.... mmc ic jumjer
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-15-2011 13:08
Page generated in 0.17848 seconds with 9 queries
