07-02-2008, 14:19 | #1 (permalink) |
Freak Poster Join Date: Jul 2007 Location: Bangladesh
Member: 549796 Status: Offline Thanks Meter: 56 | nokia 2626 RE-start Problem, My Phone is Water Damage, I Clean The phone with thener & put under light , Then i Full erase the phone & i wright the full flass and wright good Pm But my phone is RE-Start. What is the problem & what can i do now ? Pls help me. MOBILE PLUS |
The Following User Says Thank You to Mobile_plus For This Useful Post: |
07-02-2008, 16:13 | #2 (permalink) |
Freak Poster Join Date: Aug 2007 Location: nowadays in uae
Member: 574119 Status: Offline Thanks Meter: 29 | Ur Mobile May Be Short Pls Chk Irst For Shortage ,after Give Heat For Dryness And Try To Flash Completely If Can Take Self Test Of Mobile Thats Good Other Wise Problem Of Cpu ,reflow Flux |
The Following User Says Thank You to SHAHID99 For This Useful Post: |
07-03-2008, 00:14 | #5 (permalink) |
No Life Poster Join Date: Oct 2002 Location: PARIS
Member: 16856 Status: Offline Sonork: 1582037 Thanks Meter: 441 | Why have we got people who always suggest to flashing the phone ?? There is absolutely no need to flash software to fix a water damaged or oxidised phone !!! Worse yet, you can kill the phone for good doing that if error happens during the flash procedure (erase/write) ! Beware, next time if any LCD is broken , some people 'll probably advice you to flashing it BR Max_B |
The Following User Says Thank You to Max_B For This Useful Post: |
07-03-2008, 05:04 | #6 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: http://meo786.forumotion.com/ Age: 50
Member: 465162 Status: Offline Thanks Meter: 683 | Dear, nice information, but please describe the all steps how we handle the phone that is water damage. your describtion must be step by step for under standing of new guys. Thanks in advance. Quote:
The Following User Says Thank You to meo786pk For This Useful Post: |
07-03-2008, 15:21 | #7 (permalink) |
Member: 16856 Status: Offline Sonork: 1582037 Thanks Meter: 441 | If phone gets contact with moisture : First thing to do ask to customer when did it happen ? One hour ago ? One Day ago ? More than a one day ? What is the fault customer is describing ? No sound, no display, no network, reboots, completely dead ... Warn the customer the phone might getting dead during the repair work !!! Hit a rusty nail with a hammer can break it Did the customer removed battery asap or if he didn't ? if not then repair will be harder to perform because of burn inside. (electricity + water + metal) Did it been drown into water ? Sea water ? Coca cola ? Toilet water ? Because if it's sea it's probably dead, Coca colas sugar has to be cleaned with water first, if toilet then take care of yourself Now about the repair steps : First dismantle all the phone Remove all stickers, keyfoils if need, flexes, cameras, shieldings ... Make visual inspection if partial oxidation or general, is it white sulfate or is there some rust ? If sugar drink damage then clean with water because alcohol can't do nothing against it, so clean with water + brush + rag on round tweezers. Once sugar is cleaned rinse all the water with alcohol to dissipate water. If water damage then clean with alcohol, isopropanol or good board cleaner . Maybe the fault is already fixed so check it now ! If not you need do rework with flux and good solder with hot air and with soldering iron at places where there are visible black signs of burn on contacts. Don't forget to clean the flux ! If you have the schematics you can check continuity of tracks that matters to the reported fault, so you could make jumpers if that. If short circuit you can put power on to the board and check what is heating when high current consumption. Anyways if phone is still powering on, try to make as less repair as possible because it's very easy to get a brick trying to do more than you have to. In fact it's a chitty job that only few percents could finish as a success ! So don't make too much and good luck !!! BR Max_B |
The Following 3 Users Say Thank You to Max_B For This Useful Post: |
07-03-2008, 16:26 | #11 (permalink) | |
Freak Poster Join Date: Jun 2008 Location: Heaven
Member: 801083 Status: Offline Thanks Meter: 99 | Quote:
The Following User Says Thank You to AdickAsia For This Useful Post: |
n96 re start problem | allentelecom | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 02-13-2010 08:13 |
Nokia 1208 re start. | sribalaji | Nokia Hardware & Hardware Repair | 9 | 01-21-2010 07:32 |
LG-1100 Re-start problem | Mobile_plus | Infinity-Box | 6 | 01-18-2009 08:43 |
NOKIA 3110c RE START PROBLEM PLZ HLP | WHED | Nokia Hardware & Hardware Repair | 10 | 09-19-2008 09:24 |
1112 re-start problem ??? | anowar_47 | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 07-31-2007 10:58 |
