Old 02-12-2009, 08:30   #1 (permalink)
erick_ponsel88's Avatar
Member: 969971
Sonork: Vincent_Lim
Thanks Meter: 294
nokia 2626 when calling ,connection error
any solution??
urgent please
Old 02-12-2009, 08:33   #2 (permalink)
sheraz_mobiles's Avatar
Member: 724090
Sonork: 100.1601663
Thanks Meter: 88
right good pm file u r problem will be solved
The Following 2 Users Say Thank You to sheraz_mobiles For This Useful Post:
Old 02-12-2009, 08:59   #3 (permalink)
metro2mobile's Avatar
Member: 515972
Thanks Meter: 526
brother just restor difult fone
The Following User Says Thank You to metro2mobile For This Useful Post:
Old 02-12-2009, 09:09   #4 (permalink)
Member: 969971
Sonork: Vincent_Lim
Thanks Meter: 294
thanks bro
any other solutions
doesn't work
Old 02-13-2009, 01:13   #5 (permalink)
Member: 910084
Plese help !!!! 2626 contack service with battrey, if connect ufs is normal............ Thx.
Old 02-14-2009, 07:51   #6 (permalink)
Member: 515972
Thanks Meter: 526
brother chang pf and post reply
Old 02-14-2009, 07:57   #7 (permalink)
shaikh_zubin's Avatar
Member: 461699
Thanks Meter: 80
basicaly its rx tx fault find that connectint o which components n replace it bro
Old 02-14-2009, 12:03   #8 (permalink)
ABUU YUUNUS's Avatar
Member: 319112
Thanks Meter: 164
First clean the pcb with nitrocellulose thinner or spirit and erase the flash from the phone, full flash it with a higher version of flash file, write in good pm, and unlock the phone.
Old 09-02-2010, 12:23   #9 (permalink)
Crazy Poster
Member: 1335527
Thanks Meter: 5
nokia 2626 error connection after call hi problem i check to network section hi is ok pls solution's
Old 11-15-2012, 13:37   #10 (permalink)
Member: 1712309
Sonork: 8f580cbf3792776ff9df6d34b
Thanks Meter: 8
bro this is a sofware problem i solve this please use mx-key -service-online logger -dct4plus rpl and do select job your problem will be solved 100000000000000000%
The Following User Says Thank You to aadi1234 For This Useful Post:
Nokia 2626 switch off when put sim card dey mobiles Nokia Hardware & Hardware Repair 2 12-18-2009 12:57
nokia 2626 lcd connecter help? Sara-Mobiles Nokia Hardware & Hardware Repair 13 07-25-2009 15:53
N70 connection error when making calls hooi76 Nokia Hardware & Hardware Repair 2 01-14-2009 16:10
Samsung A400 problem with connecting when call SVH Samsung Hardware Repair 9 08-13-2003 23:21
Page generated in 0.17893 seconds with 9 queries
