Old 02-18-2010, 10:43   #1 (permalink)
Member: 899253
Thanks Meter: 4
6303 bluetooth+camera+video playing
hello every body
today a strange problem faced me
nokia 6303 the camera does not play and shows the camera on standby
and does not work the video and bluetooth
please can you give me the right solution
with my best regard
The Following 3 Users Say Thank You to ramiii84 For This Useful Post:
Old 02-18-2010, 13:06   #2 (permalink)
Member: 899253
Thanks Meter: 4
can any body help me please
The Following User Says Thank You to ramiii84 For This Useful Post:
Old 02-18-2010, 13:31   #3 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274/mahbubalfa
Thanks Meter: 26,433
Bro.try this solution.
http://forum.gsmhosting.com/vbb/showthread.php?t=912088
The Following 16 Users Say Thank You to mahbubalfa For This Useful Post:
Old 02-18-2010, 18:22   #4 (permalink)
Member: 899253
Thanks Meter: 4
thanks brother for your concern but as you see it is 3 problem at the same time
and it is the second time i faced the same problem and i could not fix it
may the problem from the camera parts or bluetooth parts
or some thing sharing between them
Old 02-19-2010, 12:27   #5 (permalink)
Member: 899253
Thanks Meter: 4
where are the expert
please some body give me the solution
Old 02-19-2010, 12:53   #6 (permalink)
Member: 906499
Sonork: sen-i
Thanks Meter: 47
it is baterry conector . it is faulty and have broken all contact to bluethooth and cam. i have 1 6303 , but wont repaire this it is very hard , people can make it . but not easy
The Following User Says Thank You to sen-i For This Useful Post:
Old 02-19-2010, 13:11   #7 (permalink)
prakashmborana's Avatar
Member: 600436
Thanks Meter: 219
[URL=http://img638.imageshack.us/i/came
The Following User Says Thank You to prakashmborana For This Useful Post:
Old 02-20-2010, 10:52   #8 (permalink)
Member: 899253
Thanks Meter: 4
thanks sen-i and prakashmborana for you reply but i sorry i could not see the photo
can you put it on other link please brother
Old 02-22-2010, 17:36   #9 (permalink)
SRNOURI's Avatar
Member: 29870
Thanks Meter: 24
yes,seems it is fault of battery conector but how can we repair it.I think there is lost line from BSI pin.
The Following User Says Thank You to SRNOURI For This Useful Post:
Old 02-23-2010, 09:44   #10 (permalink)
Member: 906499
Sonork: sen-i
Thanks Meter: 47
not bsi line, all way under baterry connector , for me it was 5 way under "-",9 way under "bsi" , and 2 way under "+". very hard work . i have back the phone , but if you have guaranti for phone go to nokia service and i think it is nokia fault for this model. they need replased mainboard , or repair this , conector is lose bks , oil was under conector and it was not ok
Old 03-03-2010, 20:41   #11 (permalink)
Gsm Benghazi's Avatar
Member: 412609
Sonork: 100.1586824
Thanks Meter: 148
Originally Posted by ramiii84 View Post
hello every body
with my best regard
BIG GSM FORUM with 1,250,244 Members no solution no post reply ( reading only and leave )
where Moderators ?
Where experts ؟
big problem w/o solution
( 6303 bluetooth+camera+video playing problem )
Do not skimp on helping others
best regards for all my friend
The Following User Says Thank You to Gsm Benghazi For This Useful Post:
Old 03-03-2010, 20:52   #12 (permalink)
Member: 412609
Sonork: 100.1586824
Thanks Meter: 148
here phone test by mx-key
Phone Type: RM-443
SW version: V 06.40 30-04-09 RM-443 (c) Nokia
ID Test name Startup Result
3 EAR_DATA_LOOP Y passed
12 SIM_CLK_LOOP Y passed
13 SIM_IO_CTRL_LOOP Y passed
15 SLEEP_X_LOOP Y passed
46 UEM_CBUS_IF Y passed
7 KEYBOARD_STUCK N passed
22 CAMERA_IF N !no signal
43 LCD N passed
21 LPRF_IF N !no signal
44 LPRF_AUDIO_LINES N !no signal
2 CURRENT_CONS N passed
42 RADIO Y passed
69 BACKLIGHT Y passed
33 SIM_LOCK N passed
93 SECURITY N passed
71 BT_WAKEUP N !no signal
96 HOOKINT N passed
88 TAHVOINT Y passed
101 BTEMP N passed
32 AMB_LIGHT_SENSOR N !no signal
119 IIC N passed
222 LED_CONTROLLER N passed
56 CDSP_SLEEPCLK_FREQ N passed
128 CDSP_SLEEPCLOCK_FREQ N passed
86 CDSP_RF_BB_IF N passed
77 CDSP_GSM_TX_POWER N passed
83 CDSP_RF_SUPPLY N !failed !
80 CDSP_TX_PLL_PHASE_LOCK N passed
82 CDSP_PWR_DETECTOR_BIAS N passed
81 CDSP_RX_IQ N passed
Old 03-05-2010, 22:32   #13 (permalink)
Member: 412609
Sonork: 100.1586824
Thanks Meter: 148
In Nokia Hardware & Hardware-Repair section no post reply
where all Moderators ?
( Pandemonio100, Raheeeeb, stanner_austin, Drug_Store, ..::Neo::.., Syed, simonng83, ..::ArchitRaj::.. )
no one here
no regards
Old 03-05-2010, 23:30   #14 (permalink)
Member: 412609
Sonork: 100.1586824
Thanks Meter: 148
HERE SAME PROBLEM
http://forum.gsmhosting.com/vbb/show...highlight=6303
BEST ANALYSIS
Originally Posted by Azatmuhammet View Post
If telephone doesn`t play video, and bluetooth doesn`t work then 100% tracks are damaged under the battery connector.
BUT HOW CAN WE SUBSTITUTE THIS track ?
The Following 2 Users Say Thank You to Gsm Benghazi For This Useful Post:
Old 03-07-2010, 16:52   #15 (permalink)
Member: 412609
Sonork: 100.1586824
Thanks Meter: 148
here last solution
Try careful heating of RAPGSM+Combo memory stack and HWA to check for a soldering issue. Test the
camera function after this action.
If the camera still does not work, then a track below the battery connector has been damaged
the track below the battery connector has been damaged
It is not possible to repair these internal tracks
The Following 4 Users Say Thank You to Gsm Benghazi For This Useful Post:
6303 bluetooth+camera+video not playing help need abdurrahimsagar Nokia Hardware & Hardware Repair 15 09-11-2013 20:25
6300 blue tooth+camera+video playing abdurrahimsagar Nokia Hardware & Hardware Repair 5 05-20-2011 13:59
6233 camera and play video after restart solution 100% ok hajukhan Nokia Hardware & Hardware Repair 14 05-08-2011 10:25
hı..help 6500 not video playing and camera proton Nokia Hardware & Hardware Repair 1 01-07-2010 19:22
6500s Camera not working and no video play Pratheesh T K Nokia Hardware & Hardware Repair 0 12-17-2009 14:51
Page generated in 0.28063 seconds with 10 queries
