08-02-2009, 14:51 | #1 (permalink) |
No Life Poster Join Date: Aug 2004 Location: pakistan Age: 38
Member: 78884 Status: Offline Sonork: mohsin111 Thanks Meter: 92 | N73 start up failed !!!!!! and imei 12345 set on calling and camera each 1 ok but every 10,20 min laters set off after rpl write set start up failed iam check "self test" there (st_security test : fail) here log n73 MCU SW version: V 05wk47v60.1 20-03-08 RM-133 (c) Nokia. HW version: 6000 PCI version: RFIC version: 17211721 Retu version: 15 Tahvo version: 22 Production serial number: SBH144666 Product code: 0529607 Module code: 0202855 Basic production code: 0527006 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 35354602413XXXX IMEI spare to net: 3A 35 45 06 42 31 64 07 IMEI SV to net: 33 35 45 06 42 31 64 77 F5 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN plzz help me thanksss in advanceeeeee |
08-02-2009, 15:14 | #3 (permalink) | |
Member: 78884 Status: Offline Sonork: mohsin111 Thanks Meter: 92 | dis is different fault dear Quote: | |
11-15-2010, 06:10 | #6 (permalink) |
Registered User Join Date: Apr 2008 Location: sadiqsajan
Member: 759011 Status: Offline Sonork: 164643 (server.sonork.com Thanks Meter: 152 | N73 start up failed use mexhey and write pm 1&309 100% your problem slove................ |
The Following User Says Thank You to sadiq123 For This Useful Post: |
nokia n73 start up failed contect retailer | theonly1 | Nokia Hardware & Hardware Repair | 17 | 09-15-2010 11:42 |
N73 start up failed !!!!!! | Mohsin_josh | Nokia Base Band 5 ( BB-5 ) | 4 | 08-02-2009 20:52 |
N73 Start Up Failed Contact The Retaler | randr | MT-BOX | 1 | 12-15-2007 06:45 |
plz help me wt n73 start up failed after rpl | abcrino50 | MT-BOX | 16 | 06-23-2007 20:08 |
