03-26-2009, 13:53 | #1 (permalink) |
Freak Poster Join Date: Jan 2008 Location: punjab ,jalandher
Member: 672494 Status: Offline Thanks Meter: 109 | nokia 2680s-2 problem |
The Following User Says Thank You to laddimobile For This Useful Post: |
05-09-2009, 20:51 | #3 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Caribbean
Member: 237911 Status: Offline Thanks Meter: 632 | some says the problem is the flex cable, we try it, but it never solve the problem, some say it has a connection with the pm, i tried to read a pm of a working one and write it on the one with the problem but it also never solve the problem some say its the watchdog which cause the phone to power off, we recieve 2-3 pcs of 2680 with that kind of problem and were still trying to solve whats the real reason it is powering off, hope somebody can share his experiences here regards |
06-01-2009, 21:56 | #8 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Unlock world
Member: 242469 Status: Offline Thanks Meter: 503 | when your phones is damaged in watter you make following steps 1.- Clean your PBC in ultrasonic 2.- Aplly hot gun in PBC 3.- Full flash + full PM B.R |
06-02-2009, 02:54 | #9 (permalink) |
Freak Poster Join Date: Nov 2008
Member: 895524 Status: Offline Thanks Meter: 33 | lol will be smart idea wouldnt it to clean up the corrosion then get rid of the gunk under ic with the ultrasound first then dry and test for shorts b4 changing parts. But reading the power output of the phone when its both off and on are a good indication of where there could be a problem. |
08-12-2009, 14:27 | #10 (permalink) |
Freak Poster Join Date: Mar 2005 Location: Abuja, Nigeria west Africa. Age: 52
Member: 129947 Status: Offline Thanks Meter: 16 | i have the same problem try flashing it complete but still the same. But if u put a charger in the phone it will not tip off you con make call with it but when you remove the charger the phone will just off. need a solution please thanks in advance. |
08-12-2009, 14:54 | #11 (permalink) |
nokia 2680s-2 malfunctining problem | de brain box | Nokia Hardware & Hardware Repair | 6 | 03-04-2011 11:08 |
Nokia 2680s-2 RM-392 how to convert 1800 to 1900? | BeaulieuM | Nokia Hardware & Hardware Repair | 3 | 10-27-2010 13:44 |
