Old 03-28-2011, 05:10   #1 (permalink)
rekha1255's Avatar
Member: 333796
Sonork: 100.1587155
Thanks Meter: 83
Question nokia 2690 cs With battry But working with box
One nokia 2690 working ok with UFC + mx n show c/s with battry
Here is log
Version Info:
MCU SW version: V 10.10 22-04-10 RM-635 (c) Nokia
HW version: 3000
RFIC version: 06540601
DSP version: ICPR72_10w06
LCD version: SUEZ
PPM version: V 10.10 22-04-10 RM-635 (c) Nokia MH
BT MCM version: 2.31-SP2.26
Retu version: 16
Tahvo version: 22
Bluetooth ID: 20 D6 07 00 65 31
DVB-H receiver Bootloader version: 1e
Product Info:
Production serial number: 12CA4A8AI
Product code: 0592107
Module code: 0204458
Basic production code: 0589255
Long production SN: 0
Serial Numbers:
IMEI plain: 353XXXXXXXXXX59
IMEI spare to net: 3A 35 04 09 04 52 09 05
IMEI SV to net: 33 35 04 09 04 52 09 55 F8
Other Info:
Model: Nokia 2690 (Classic Phone)
CS type: GSM850/GSM900/GSM1800/GSM1900
BSI: 5.5 KOhm
Imei net: 353XXXXXXXXX059
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFF
Its was Water demeg . i was reball betty n avilma n re hot Combo
If anyone have Tested sloution Please Share with us
Thanks
Old 03-28-2011, 05:13   #2 (permalink)
mobilecare.vcl's Avatar
Member: 1334005
Sonork: 100.1601457
Thanks Meter: 362
check on off switch / batty / and cnnector
Old 03-28-2011, 05:25   #3 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,377
It seams to Hardware fault
For software , check BUS check / self test & check Security fail or not
Old 03-28-2011, 05:58   #4 (permalink)
Member: 1334005
Sonork: 100.1601457
Thanks Meter: 362
70% its on/off switch problum
Old 03-28-2011, 09:26   #5 (permalink)
bablu333's Avatar
Member: 1495471
Sonork: 1603910:abubablu
Thanks Meter: 1,582
Here is log
Version Info:
HW version: 3000
LCD version: SUEZ
Retu version: 16
Tahvo version: 22
Product Info:
Serial Numbers:
Other Info:
BSI: 5.5 KOhm
Counter: 0/3, 0/10
Thanks
check bsi line.and bsi+graund sort.solve ur problem
Old 03-29-2011, 04:22   #6 (permalink)
rekha1255's Avatar
Member: 333796
Sonork: 100.1587155
Thanks Meter: 83
How can it possibal GND+BSI ?
Its not trun on without BSI . Im confuse
Old 03-29-2011, 04:23   #7 (permalink)
rekha1255's Avatar
Member: 333796
Sonork: 100.1587155
Thanks Meter: 83
All test passed .As I told that working with Fbus cable with UFS . Not working with battry only .
Old 03-29-2011, 05:45   #8 (permalink)
imran zafar's Avatar
Member: 328187
Thanks Meter: 1,687
can u post ur self test log here?......
check set consumption is that normal???
witch area was maximum damage by water??
clean all pcb many time
try to replace avilma and check......post reply
Old 03-29-2011, 07:46   #9 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,469
bro srinibas security test-failed cant make this problem
Here is log
Version Info:
HW version: 3000
LCD version: SUEZ
Retu version: 16
Tahvo version: 22
Product Info:
Serial Numbers:
Other Info:
BSI: 5.5 KOhm
Counter: 0/3, 0/10
Thanks
bro this cause mainly hardware check BSI line and avilma(reflow)
post result
Old 03-29-2011, 09:15   #10 (permalink)
rekha1255's Avatar
Member: 333796
Sonork: 100.1587155
Thanks Meter: 83
post result
Also re ball n change too avilma IC ... ( not Profit )
Now COMBO reballing ..
Old 03-29-2011, 09:20   #11 (permalink)
Member: 351924
bro no need to reball combo
u can change avilma or check bsi status
Old 03-29-2011, 12:20   #12 (permalink)
rekha1255's Avatar
Member: 333796
Sonork: 100.1587155
Thanks Meter: 83
Yaar also change Avilma , read naa .
"Also re ball n change too avilma IC ... ( not Profit )"
Old 03-29-2011, 12:34   #13 (permalink)
Member: 351924
BRO INSERT BATTERY AND INSERT CHAGER
THEN CHECK PHONE SHOW CHARGING OR NOT
Old 03-29-2011, 13:09   #14 (permalink)
Member: 328187
Thanks Meter: 1,687
dear sir.....i think he saying his set is on contact service (c/s) mode
with battery .......may b its lcd problem? may b still software problem
he must check UI related components.......if bsi problem then set can not show local mode with fbus flashing and cant power up with battery.....finely reball cpu+ram
The Following User Says Thank You to imran zafar For This Useful Post:
Old 03-29-2011, 16:23   #15 (permalink)
rekha1255's Avatar
Member: 333796
Sonork: 100.1587155
Thanks Meter: 83
finally .. set dead . n heat avilma when power press.
coz Combo was reballed .
Page generated in 0.34766 seconds with 10 queries
