-   Nokia Hardware & Hardware Repair (http://forum.gsmhosting.com/vbb/f148/)
-   -   Nokia 2690 Only nokia logo than white screen and switch off. (http://forum.gsmhosting.com/vbb/f148/nokia-2690-only-nokia-logo-than-white-screen-switch-off-1382425/)
omtanwer1 11-16-2011 11:20
How solv this problem...........
saunit 11-22-2011 08:01
2690 nokia logo only
dear all
i have nokia 2690 only nokia logo and white then switch off
any solutiong for this
and during flash after flash failed error
akhtarmughal 01-04-2012 10:03
flash latest version
or post here log
anujc143 01-04-2012 15:56
1. chage camara
2. chage blututh ic
3. mmc ic
4.remove the hf ic
salmaan shaik 03-16-2012 17:12
or post here log
same problem boos wats up soltion man its urgent
akhtarmughal 03-17-2012 06:47
check hardware bro
camera Bluetooth ic mmc ic etc
realmadrid 03-19-2012 15:16
MCU Nokia Version: 1.132, and up to date.
SMCU Nokia Version: 1.44, and up to date.
Initializing flasher...
Initializing
Scanning image files...
1. Make sure USB cable, Battery and charger are removed from device.
2. Insert USB cable to device
3. Insert Battery to device
Waiting for USB device...
Loading secondary boot code: 14592 bytes
Secondary boot loaded
Loading update server code: 300160 bytes
Update server loaded
Asic CMT: Verifying communication to device...
Asic CMT: Start programming 29095 KB...
Asic CMT: Erasing rm635__10.10.mcusw
Asic CMT: Erasing area 1...
Asic CMT: Erasing area 2...
Asic CMT: Erasing area 3...
Asic CMT: Erasing area 4...
Asic CMT: Erasing area 5...
Asic CMT: Erasing area 6...
Asic CMT: Erasing rm635__10.10.ppm_ae
Asic CMT: Erasing rm635__10.10.image_ae_silver_fr
Asic CMT: Programming rm635__10.10.mcusw
ADL LDR: Error sending ADL_LDR_WRITE_DATA_REQ size 0xC000
ADL LDR: Error sending write message...
ADL LDR: Resending Prepare for Write Request....
ADL LDR: Error writing to target address 0x01398400, Size 0x0000C000
Asic CMT: ERROR Programming rm635__10.10.mcusw Block 38. Unable to continue flashing.
Asic CMT: Error in sending data from rm635__10.10.mcusw.
Protocol 1: Error during Flashing. Unable to continue.
Unable to flash phone 0x84012283
TBB5USBFlashThread 2.9.7.2928 finished at: 2012/03/19 15:14:33
Terminated with error: Firmware: Firmware updating failed. Error 0x84012283 - Flash: Critical error while programming CMT data. Flashing operation aborted [00010123]
MCU Boot Version: 1.069, and up to date.
SMCU Boot Version: 1.34, and up to date.
Device opened at USB->Universal Box [UBEA9XDB]
any solution ???
jawad_anis 03-19-2012 16:03
( realmadrid) u plz try to flash with f-buss cable then post result and use new version its lastest version is 10.65
realmadrid 03-19-2012 19:29
the same problem with 10.65 amd not supported with fbus in ubb. id boot not supported ...
kifayatjan 06-08-2012 08:56
i have sem prolem flash ok in atf box
arsh_33 11-11-2013 09:11
cpu problam change cpu 100% solve
Page generated in 0.24612 seconds with 5 queries
