07-11-2011, 09:51 | #1 (permalink) |
Freak Poster Join Date: Mar 2008 Location: jodhpur Age: 40
Member: 737954 Status: Offline Sonork: Mobile Thanks Meter: 107 | Nokia 2690 power on after 10-12 sec auto power off |
The Following User Says Thank You to jodhpur_raj For This Useful Post: |
07-11-2011, 10:02 | #2 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | post in details mate , is it water damage?? also post here selftest result. |
The Following User Says Thank You to .:SARCAR:. For This Useful Post: |
07-11-2011, 10:04 | #4 (permalink) |
Member: 737954 Status: Offline Sonork: Mobile Thanks Meter: 107 | Phone Type: SW version: ID Test name Startup Result 3 EAR_DATA_LOOP Y PASSED(00) 12 SIM_CLK_LOOP Y PASSED(00) 13 SIM_IO_CTRL_LOOP Y PASSED(00) 15 SLEEP_X_LOOP Y PASSED(00) 46 UEM_CBUS_IF Y PASSED(00) 7 KEYBOARD_STUCK N !NOT EXECUTED(03) 22 CAMERA_IF N !NOT EXECUTED(03) 20 BACKUP_BATT N !NOT EXECUTED(03) 43 LCD N !NOT EXECUTED(03) 21 LPRF_IF N !NOT EXECUTED(03) 44 LPRF_AUDIO_LINES N !NOT EXECUTED(03) 2 CURRENT_CONS N !NOT EXECUTED(03) 42 RADIO N !NOT EXECUTED(03) 69 BACKLIGHT Y PASSED(00) 33 SIM_LOCK N !NOT EXECUTED(03) 93 SECURITY N !NOT EXECUTED(03) 71 BT_WAKEUP N !NOT EXECUTED(03) 96 HOOKINT N !NOT EXECUTED(03) 88 TAHVOINT Y PASSED(00) 101 BTEMP N !NOT EXECUTED(03) 119 IIC N !NOT EXECUTED(03) 108 EXT_DEVICE N !NOT EXECUTED(03) 56 CDSP_SLEEPCLK_FREQ N !NOT EXECUTED(03) 128 CDSP_SLEEPCLOCK_FREQ N !NOT EXECUTED(03) 86 CDSP_RF_BB_IF N !NOT EXECUTED(03) 83 CDSP_RF_SUPPLY N !NOT EXECUTED(03) 80 CDSP_TX_PLL_PHASE_LOCK N !NOT EXECUTED(03) 81 CDSP_RX_IQ_LOOP_BACK N !NOT EXECUTED(03) 77 CDSP_GSM_TX_POWER N !NOT EXECUTED(03) |
07-11-2011, 10:30 | #6 (permalink) |
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | hwk selftest log not complete mate !! check simlock data , superdonglekey data , security in other software . seems sd key corrupted , check. |
07-13-2011, 10:44 | #10 (permalink) |
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | @jodhpur_raj , ok mate , try to full flash d unit first before going to hardware repair . means backup all important certificates including simlock data then erase flash . after that reflash with latest version . restore all certificates including simlock data. make sx4 auth & write pm 1-309 then check. please post here d result P.S.-make sure & it's important to backup all certificates before erase flash.as this is sl3 type phone simlock data also needed to backup. if still same clean pcb very well then check. also post result |
08-17-2011, 06:03 | #13 (permalink) | |
Member: 737954 Status: Offline Sonork: Mobile Thanks Meter: 107 | Quote:
08-17-2011, 12:42 | #14 (permalink) |
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | ok , then sure it's a hardware problem . check sleepclk voltage 2.8v from betty (check schematics for testpoint). if found no or abnormal voltage need to change betty. also check vio,vcore,vdram,vaux,vr1,vr2 voltages from avilma . then let me know. (no need to reflow or reball combo ic now) |
