Old 04-03-2013, 09:04   #1 (permalink)
Member: 1748687
Sonork: 100.1656932
Thanks Meter: 26
nokia 2700c just on nokia logo then off
nokia 2700c just on nokia logo off
i flash it but same problem here is the logo any idea
1ST BOOT : C0,07 [Rm-561] [2.2.0.0]
CMT ASICID: 000000010000022600010006030C192101033000
EM 1 ID : 00000296
EM 2 ID : 00000B22
CMT PUBID : 08A000193D86055696B45C676A99D88E12DC0FC9
CMT MODE : 00
CMT HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723
CMT ROMID : 273F6D55DFAAF68F
CMT 1ST Boot OK
CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1
CMT FLID0 : 00EC2400-00008A31, Sam K8x1259ETF
CMT FLCNT : 00000000000000000000000000000000000000
CMT MCID0 : FFFF0000-00000000
CMT 2ND Boot OK
CMT ALGO : RAP3Gv3_algo.fg, Ver: 9.17.0
CMT KSIG0 : 3EA22A1DDA660002E56108DB5072A10F8709443F
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
IMAGE : rm561__09.98.mcusw
CMT NOR Erase Area: 0x00000000-000006BF
CMT NOR Erase Area: 0x000006C0-0001FFFF
CMT NOR Erase Area: 0x00040000-000BFFFF
CMT NOR Erase Area: 0x000C0000-0013FFFF
CMT NOR Erase Area: 0x00140000-0137FFFF
CMT NOR Erase Area: 0x01380000-0151FFFF
CMT FLASH ERASE OK, Time: 01:18
Written: 8 Certificate(s)
CMT FLASH WRITE OK, Time: 01:57
Chip SECTOR_SIZE: 128k
Warning, Must be Used 128Kb Sector_Size CNT File
CONVERSION: Already 128K Paged Source
IMAGE : rm561__09.98.image_mr_blac
CMT NOR Erase Area: 0x01DC0000-0215FFFF
CMT NOR Erase Area: 0x02160000-03FBFFFF
CNT FLASH ERASE OK, Time: 01:17
CNT FLASH WRITE OK, Time: 01:10
IMAGE : rm561__09.98.ppm_mr
CMT NOR Erase Area: 0x01520000-01DBFFFF
PPM FLASH ERASE OK, Time: 00:21
PPM FLASH WRITE OK, Time: 00:39
Flashing Completed, Rebooting Mobile
The Following User Says Thank You to Anamul telecom For This Useful Post:
Old 04-03-2013, 09:14   #2 (permalink)
Member: 1306485
Thanks Meter: 9
avilma(POWER IC) ic se problame hai
The Following User Says Thank You to shanubaba For This Useful Post:
Old 04-03-2013, 09:16   #3 (permalink)
Member: 1022587
Thanks Meter: 2
bro change bluetooth ic n camera it will be 100% ok
Old 04-03-2013, 11:10   #4 (permalink)
zubair pathan1's Avatar
Member: 1867883
Sonork: 100.1654594
Thanks Meter: 27
no avilma or betty ic problem
Old 04-03-2013, 11:24   #5 (permalink)
Member: 1427033
Sonork: 100.1596688
Thanks Meter: 1,204
EM 1 ID : 00000296
EM 2 ID : 00000B22
CMT MODE : 00
CMT 1ST Boot OK
CMT 2ND Boot OK
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
Bofore doing any job.1st try to Formet user area moro than 3times then post result.
Old 04-03-2013, 13:53   #6 (permalink)
Member: 364927
Thanks Meter: 17
just flash mcu 9.98 ppm 9.97 cnt 9.97 100% solve
Old 04-03-2013, 14:01   #7 (permalink)
aliyousafzai's Avatar
Member: 1358184
Sonork: 100.1616912
Thanks Meter: 615
if problem same after flash then remove camera
Old 04-03-2013, 14:06   #8 (permalink)
mahzra azra's Avatar
Member: 1722956
Sonork: mybestfriend.adeel
Thanks Meter: 305
EM 1 ID : 00000296
EM 2 ID : 00000B22
CMT MODE : 00
CMT 1ST Boot OK
CMT 2ND Boot OK
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
bro this prolem is from combomic .
changed combo and flash ic 10000000% your problem will be okkkkkkkkk
Old 02-09-2014, 13:38   #9 (permalink)
Member: 1145495
Sonork: 1638564
Thanks Meter: 2
Clean Pcb specially RAP IC put it under 40/50w bulb for 30-60 minute 100% work
Old 02-26-2014, 23:13   #10 (permalink)
Member: 669559
Thanks Meter: 156
Thumbs up nokia 2700c just on nokia logo then off - solution 100% tested
Look HERE
Page generated in 0.25872 seconds with 8 queries
