Nokia 2700c restart problem Nokia 2700c is restart i am trying to full flash flash is complete but problem not salve help me |
try to check the power ic and cpu ic there may be a short one component..... |
i rehot flash ic and all any other? |
chenge lcd & clean lcd connector |
I need the solution too.Both 2700c and 5310 music xpression behave like this. Please anyone with the solution ? |
Check PM file, write newone, Check Security test, Check IMEI. |
i have many set to solve but no real solution yet. my phone are too new, never wet by water, never drop down, i think it cuz of software i've try with many tools but my problem not solved. here is the log i flash with v9.98 Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010) Processing MCU file: rm561__09.98.mcusw [BB5,BB5 ALGORITHM] size: 19.41 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Pooling for ADL device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 2EF3413C CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] CMT EM0 ID: 00000296 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 1520020113B68E5648711BAC1ED81741550DCDA3 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID: 273F6D55DFAAF68F Flashing CMT Update Server Data, ULO: 0x3900 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, UPDAPP: 0x4B340 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, PASUBTOC: 0x59980 bytes Update Server code succesfully sent to phone. Pooling for ADL device ... Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, ID: 34B84F05 Verifying communication to device OK. Erase size: 21.00 MB CMT NOR area [00000000-000006BF] erased in 0.578 s CMT NOR area [000006C0-0001FFFF] erased in 0.594 s CMT NOR area [00040000-000BFFFF] erased in 2.328 s CMT NOR area [000C0000-0013FFFF] erased in 2.500 s CMT NOR area [00140000-0137FFFF] erased in 1 min 14.750 s CMT NOR area [01380000-0151FFFF] erased in 6.875 s Flash programming ... CMT PAPUBKEYS: 3EA22A1DDA660054937DB77F2B8852B100000000 (RAP Certificate 202 v.1) written. Programming completed in 1 min 36.578 s Processing PPM file: rm561__09.98.ppm_vc [BB5,BB5 ALGORITHM] size: 6.52 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 8.62 MB CMT NOR area [01520000-01DBFFFF] erased in 36.594 s Flash programming ... Programming completed in 32.891 s Processing CNT file: rm561__09.98.image_vc_blac [BB5,BB5 ALGORITHM] page size: 128 K size: 10.89 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 34.00 MB CMT NOR area [01DC0000-0215FFFF] erased in 15.640 s CMT NOR area [02160000-03FBFFFF] erased in 2 min 1.625 s Flash programming ... Programming completed in 52.922 s Total time for flashing process(boot+erase+write) was 7 min 45.735 s Pooling for ADL device ... Device found: nmwcdc\Nokia 2700 classic USB Generic, ID: 1BE3B9EC Verifying communication to device OK. Flashing completed in 8 min 35.312 s Phone Type: RM-561 (Nokia 2700 classic) SW Version: V 09.98 06-09-10 RM-561 (c) Nokia Imei plain: 35337604259xxx-x Product Code: 0579809 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 35337604259xxxx Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
try to downgrade, sometimes that works. |
5130 2700 Nokia logo then wight display then off solution here 99% fast try full flash higher version not ok......... second try this solution see pic............. mmc ic and camera replace enjoy ....................... |
2700 pic restart problem http://img690.imageshack.us/img690/5...artsolutio.jpg |
2700 full flash but notui seting and factry defolt help me any idia [email protected] |
2700c full flash ok but after some times letter restrat 100% solution any body please help |
remove bt ic 100% problem sovld |
