04-07-2010, 08:10 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Barisal Age: 44
Member: 1427033 Status: Offline Sonork: 100.1596688 Thanks Meter: 1,204 | Nokia 2760 contactservic done 1,st erase the phon 2,nd flash with good version 3,write this PM 4, unlock & factory link--- 4shared.com - online file sharing and storage - download contact servic pm.rar |
The Following 3 Users Say Thank You to Dooha_Bd For This Useful Post: |
04-07-2010, 23:00 | #2 (permalink) |
Junior Member Join Date: Apr 2009
Member: 1014429 Status: Offline Thanks Meter: 2 | Hi, Took several hours reading about this problem since I have a 2760 that after unlock, when switched on restarts and says contact service. When you do a self test says there is an error in simlock. Pressing simlock state, read error . I tried what you put, but when I reset user area failed me and did not go there. I flashed with different versions and always the same result on. I can do? thanks |
04-08-2010, 12:27 | #4 (permalink) |
Member: 1014429 Status: Offline Thanks Meter: 2 | thanks for your answer, but do not have the mxkey only MTBox. I continued to test and when I give unlock after flash it tells me to check the cable. But is it possible that the cable is bad if no problems flashing the phone? I despair for this Corpse Any Ideas? |
04-08-2010, 19:31 | #7 (permalink) |
Member: 1014429 Status: Offline Thanks Meter: 2 | When I try to erase user area, mt sotware returns me an error "Operation failed with error 0006" in both ... I tried to do with the 10 pin cable and easy, both error. File PM I try to upload is the one at the beginning of this post and I'm also testing a griffin forum, but do not get anything clearer ... |
help!!! nokia 1208 and nokia 2760 restart. | dary775 | Universalbox | 2 | 05-14-2009 09:31 |
nokia 2760 unlock done with cyclone box v 6.82 | yasermalik | Cyclonebox | 1 | 04-26-2009 07:59 |
