03-19-2005, 20:07 | #1 (permalink) |
Insane Poster Join Date: Nov 2004 Age: 38
Member: 93059 Status: Offline Thanks Meter: 0 | Nokia 3100 and 6120i solution needed Mama mobile how r u today.I want urgent solution for a Nokia 3100 which when pressed near Antenna gives full signals and when screws are tighten it looses all network.And Its housing is also broken from right side and then I put it together with a bonding solution.Is this problem from Board or Housing ? And a Nokia 6120i which when charged is connected shows "Charger Connected" and gives a beep.then will not charge and nothing happens. Help Needed Urgently |
08-06-2005, 19:02 | #2 (permalink) |
Freak Poster Join Date: May 2005 Age: 49
Member: 148029 Status: Offline Thanks Meter: 9 | which screw all or center screws 3100 first u check with other housing(chasis)and keep antenna connections clean. if again same may be bord or upp/uem print broken.pls heat with good tight flex or change new ic and try.more3100 and6100 problems have same. i try all ok good luck |
Nokia 3100 Contact Service Solution..... | ansari_nazeel | Nokia Digital Core Technology 4 ( DCT-4 ) | 30 | 06-01-2011 15:39 |
nokia 3100 and 3120 network solution | pradeep agrawal | Nokia Hardware & Hardware Repair | 34 | 02-21-2009 12:02 |
need help for nokia 3100 and 6610i | batch_emar | Nokia Hardware & Hardware Repair | 8 | 01-31-2008 05:13 |
