08-10-2007, 11:15 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: UK Age: 45
Member: 318277 Status: Offline Thanks Meter: 92 | Nokia 3100 Contact service!!!! need help PCB is in pretty good shape! no repaires done befor n clean, try'ed flashing with UFS bt this is what i get........ 1st Boot Ok, DCT4, UPP: 1120 Fl0: 0x01000000-0x017FFFFF,0001277E,Amd 29BDS064J Algorithm: u_amd.fia, Ver: 4.52.0 Algorithm Ok, MSID: 8410711EA24ECB0DFE85482A5C Decoded MSID: 0A6CBAE9-00C109D8-A8000000 Encoded FAID: F27977E3-F128305A-F340F124 Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00 Erasing: 0x01010000-0x0154FFFF ... Erasing Error: 8, at: 0x010A0000-0x010BFFFF, Time: 00:45 Process Failed, Repowering Mobile experts please help me its a bit urgent!!!!!!!! regards ---[email protected] |
08-10-2007, 11:19 | #2 (permalink) |
Freak Poster Join Date: Aug 2007 Location: Inside GSM
Member: 557999 Status: Offline Thanks Meter: 7 | ok, first you must to full erase flash on 00, 02, and 04, and then full flash, make sure you have backup your PM, after flashing do UI, if still no luck, try to full flash with higher version, maybe it can help you |
08-10-2007, 15:56 | #5 (permalink) | |
Member: 318277 Status: Offline Thanks Meter: 92 | Quote:
1st Boot Ok, DCT4, UPP: 1120 Fl0: 0x01000000-0x01FFFFFF,FFFFFFFF, Algorithm: u_intel.fia, Ver: 4.52.0 Erasing: 0x01000000-0x01FFFFFF ... Erasing Error: 8, at: 0x01000000-0x0101FFFF, Time: 01:33 Im a bit confuzed now! Do i have to do harware first on this now? Second thig is ,if i change d flash IC will d emie b all 0000000004? or can i fix it? pls need ur expert advice on dis! Regards | |
08-10-2007, 16:05 | #8 (permalink) | |
Freak Poster Join Date: Jun 2005 Location: http://www.paybox.me/r/mourad1 Age: 47
Member: 155016 Status: Offline Thanks Meter: 130 | Quote:
Best Regards. | |
01-08-2008, 11:27 | #13 (permalink) |
No Life Poster Join Date: Jul 2005 Location: ludhiana~india Age: 38
Member: 163833 Status: Offline Sonork: 100.1579554 Thanks Meter: 5,700 | brth reball flash ic ur problem will solve ...if not solve then there is problem in flash ic good luck..,,,,,,,,,,,,,,. |
01-08-2008, 12:14 | #14 (permalink) |
nokia 6303 Contact Service Need Help | batka88 | Nokia Base Band 5 ( BB-5 ) | 0 | 02-14-2010 19:48 |
Nokia 7310 contact service need help | Jiminay2000 | Cyclonebox | 4 | 12-29-2009 11:47 |
nokia 1208 contact service need help urgent | shok9992000@yah | Nokia Hardware & Hardware Repair | 7 | 02-19-2009 15:26 |
Nokia 3100 Contact Service | amalah | Griffin | 3 | 10-22-2004 14:55 |
Nokia 3100 Contact Service. PLEASE HELP. | Deoz | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 08-02-2004 11:33 |
