12-07-2006, 00:11 | #1 (permalink) |
Major Poster Join Date: Apr 2006
Member: 260085 Status: Offline Thanks Meter: 1 | nokia 3100 flashing problem i have string problem in nokia 3100 flashing pls help me. my problem 1st Boot Ok, DCT4, UPP: 1120 Fl0: 0x01000000-0x017FFFFF,0001277E,Amd 29BDS064J Algorithm: u_amd.fia, Ver: 4.52.0 Algorithm Ok, MSID: 8406564C0D88EBC558A5FEE92C Decoded MSID: 0A6CBAE9-009F298F-A8000000 Encoded FAID: 22906D44-4AAD1C35-5479D656 Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00 Area2: 0x01010000-0x0154FFFF Erased, Time: 00:43 Area3: 0x01680000-0x017EFFFF Erased, Time: 00:11 Area4: 0x01EB0000-0x01FEFFFF Out of Chip Bounds MCU Flashing Completed, Time: 00:32 Area1: 0x01550000-0x0167FFFF Erased, Time: 00:10 CNT Flashing Completed, Time: 00:02 Extracting Contents Package ... Init Local Mode Failed Contents Package Extracting Failed: Process Failed, Repowering Mobile i am watting ur replay Grate Sarasoft Team |
12-07-2006, 06:37 | #3 (permalink) |
Freak Poster Join Date: Sep 2003 Location: Romania - Hungary Age: 47
Member: 39503 Status: Offline Thanks Meter: 44 | If phone was working before flash than is a cable problem (check also with another phone) ... If you can flash mcu and ppm but you got no "local mode" on screen and no "info" then is a hardware problem ... try reflow UPP and MCU if is not glued ... WBR golumbu |
12-09-2006, 05:06 | #9 (permalink) |
Freak Poster Join Date: Jul 2006 Location: philippines
Member: 319976 Status: Offline Thanks Meter: 14 | remove the simcard holder sometimes the connector cable was not properly connected to the fon, and do it step by step flahsing 1st the mcu,2nd the ppm and 3rd the cnt flahsing then press the power switch if the fon cant both. load the higher version. good luck!!! |
12-11-2006, 17:14 | #11 (permalink) | |
Temporary banned !! Join Date: Jul 2005
Member: 165936 Status: Offline Thanks Meter: 29 | Quote:
01-13-2007, 04:04 | #15 (permalink) |
No Life Poster Join Date: Jan 2005 Age: 40
Member: 109036 Status: Offline Thanks Meter: 56 | no... don't change the upp... check your flash ic... Amd 29BDS064J it should be.... Sam K5U64418TM if your flash ic is... Amd 29BDS064J then you need to flash it to lower version coz it have its another ic for ram.... first erase the entire flash address... 01000000-017FFFFF then flash only mcu... try from lowest version... 3.10 then so on... then flash ppm corresponding to the version of mcu with local mode.... which is necessary for the cnt to extract... br |
Nokia 3100 Flash Problem, HELP | ZubairArain | Universalbox | 0 | 11-07-2009 07:44 |
nokia 3100 flashing problem | saqi160 | Nokia Hardware & Hardware Repair | 4 | 01-26-2009 23:08 |
Nokia 3100 Frezzing problem | Raf_06 | Nokia Hardware & Hardware Repair | 1 | 10-10-2004 14:52 |
!!! Nokia 3100 display problems !!! | OncleOh | Nokia Hardware & Hardware Repair | 4 | 04-02-2004 09:49 |
Nokia 3100 Unlock Problems | garry23 | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 02-10-2004 16:22 |
