Old 04-13-2007, 08:53   #1 (permalink)
Member: 248245
Thanks Meter: 85
Nokia 3100 Keypad not working
Nokia 3100 its keypad not work but some 5 to six keys work and hang i rehot UPP and Flash but not in vain any person/master fix this?
The Following User Says Thank You to zakir375 For This Useful Post:
Old 04-13-2007, 09:04   #2 (permalink)
Member: 47625
Thanks Meter: 12
100% solution here it is ...............if u have controls on your hands ...to remove dry solder of upp+uem ,deeply heat these parts ,dont pour liters of flux ....pls good luck
Old 04-19-2007, 12:18   #3 (permalink)
sms-india's Avatar
Member: 156414
Thanks Meter: 60
not any solution brother.....
Old 04-19-2007, 12:49   #4 (permalink)
gsm-iran's Avatar
Member: 188646
Thanks Meter: 76
hi
will u try rebool upp.............?
Old 04-19-2007, 13:06   #5 (permalink)
Member: 201126
any solution brother.....?
Old 04-19-2007, 13:12   #6 (permalink)
Yuvi's Avatar
Member: 226587
Sonork: 100.1603781
Thanks Meter: 352
change the upp your phone will b ok
i tested
b,r
yuvi,
Old 11-09-2007, 16:24   #7 (permalink)
ashraf_bcs's Avatar
Member: 303373
Sonork: 100.1584377
Thanks Meter: 1,241
3100 1 4 7 * Not Working.any Jumper Solution Plz...
Thanks In Advanch..
Ashraf
Old 11-09-2007, 17:42   #8 (permalink)
Registered User
Member: 483748
Thanks Meter: 47
Thanks In Advanch..
Ashraf
JUST REBALL UPP, IS THE SOLUTIONS OF URS PROBLEMS. JUST DO IT U WILL FIND UR PROBLEM SOLVED.
Old 11-09-2007, 20:57   #9 (permalink)
sopnil's Avatar
Member: 528679
Thanks Meter: 268
hi, atfirst rehot upp and little bit shaking the upp and give him to cool then check .your set will be ok.if not ok then reball upp.......good luck
The Following User Says Thank You to sopnil For This Useful Post:
Old 11-10-2007, 03:33   #10 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
change upp ,ur problem will be solved!
Old 01-18-2009, 18:20   #11 (permalink)
saqib_islam's Avatar
Member: 446881
Thanks Meter: 707
Your problem is 100% Solved Here. Just Check this out.
3100 keypad ways
mobile repairing picture help
If you like the post please hit thanks button
The Following 3 Users Say Thank You to saqib_islam For This Useful Post:
Urget Help! Nokia 7610 Keypad Not Working twinkle99 Nokia Hardware & Hardware Repair 6 06-19-2012 09:46
nokia 7210 keypad not working nellabe Nokia Hardware & Hardware Repair 7 03-10-2011 12:09
Nokia 3100 (5) not working vipcomm Nokia Hardware & Hardware Repair 21 08-01-2007 14:31
Nokia Nokia 2600 keypad not working zakir375 Nokia Hardware & Hardware Repair 2 11-30-2006 22:22
Nokia 6630 keypad not working and not charging adeel786 Nokia Hardware & Hardware Repair 7 06-24-2006 01:22
Page generated in 0.20384 seconds with 10 queries
