04-08-2005, 07:01 | #1 (permalink) |
Freak Poster Join Date: Mar 2004 Age: 47
Member: 58704 Status: Offline Sonork: 100.1618753 Thanks Meter: 43 | nokia 3100 lcd problem got any solution can sovle it.. |
04-08-2005, 09:06 | #3 (permalink) |
No Life Poster Join Date: Jun 2002 Location: CTSA Age: 46
Member: 12660 Status: Offline Thanks Meter: 7 | @ desmond2727 You will proberly find the LCD connector on the PCB is has damaged pads try resolder it first then check the picture supplied by tostefo Regards D. |
04-08-2005, 09:15 | #4 (permalink) |
Freak Poster Join Date: Aug 2004 Location: spain Age: 46
Member: 79485 Status: Offline Thanks Meter: 47 | mmm.... hi man... may be few things: 1.- check your lcd conector on board, try to resolder it, perhaps any point is desoldered 2.-It could be a common problem on 3200 and 6100, many kinds of lcd controler (on lcd) are not compatible with mcu version, try to upgrade or downgrade your phone´s firmaware or simply lcd contrler is not compatible with your board, for example, original displays with philips controler are compatible with almost every phone (you can notice orange flex circuit on lcd), other ver. of lcd controler may not be compatible with your phone (green flex display) 3.- check your lcd conector, it can be damage as the lcd board conector is, this is a common problem too. 4.- reflow upp, as lthe last solution |
Nokia 3100 LCD Blank | uwenk98 | Nokia Hardware & Hardware Repair | 8 | 12-26-2010 10:41 |
nokia 3100 lcd problem | hakouna | Nokia Hardware & Hardware Repair | 3 | 08-19-2008 17:22 |
Nokia 3100 LCD Blank | zubairok | Nokia Hardware & Hardware Repair | 4 | 09-03-2006 17:30 |
how can i make nokia 3100 lcd light | mkwatis | Nokia Hardware & Hardware Repair | 0 | 05-23-2006 18:07 |
Nokia 3100 LCD Blank | uwenk98 | Nokia Hardware & Hardware Repair | 1 | 03-06-2004 07:55 |
