Old 06-04-2006, 04:37   #1 (permalink)
celluniversal's Avatar
Member: 139388
Thanks Meter: 98
Nokia 3100 No Network Some Times
NOKIA 3100 working fine but some times network gone(no network bars) then after some hours network comes automatically(without doing anything)
This will repeat atleast 2 or 3 times in one day
I reballed the hagar ic result working fine for somedays without any problem then after a few days same problem repeated.
I made full erase and flashed the phone with 6.11 version but no result same problem
I changed the hager ic too but no use same problem
ANYBODY HAVE SOLUTION????
Old 06-04-2006, 08:13   #2 (permalink)
gokul2005's Avatar
Member: 169384
Thanks Meter: 110
Problem in Sim connector Or Sim IC. check that.........
Old 06-04-2006, 10:56   #3 (permalink)
rajiv007's Avatar
Member: 78767
Sonork: 100.95137
Thanks Meter: 566
when you dont have network in phone try to do manual network search in phone and check what is the msg you are getting it is no network found or no access
if no network found mean RX problem
if no access mean TX problem
based on this you can solve your problem
Old 06-04-2006, 13:35   #4 (permalink)
Member: 174912
Thanks Meter: 2
Just rehot UEM and it will be OK.
Old 06-04-2006, 13:44   #5 (permalink)
Registered User
BouRRi_GSM's Avatar
Member: 111457
Thanks Meter: 967
yes , i confirm , i already repair 3100 network problem without changing RF part
just rehot UEM
Old 06-04-2006, 14:42   #6 (permalink)
Member: 273997
Thanks Meter: 8
there is a white pf on the lower side of rf change it and rehot the uem 100%working
Old 06-04-2006, 16:09   #7 (permalink)
Member: 62321
Thanks Meter: 35
change antena switch and rehot upp 10000000000%
Old 06-04-2006, 16:51   #8 (permalink)
sallu's Avatar
Member: 73797
Thanks Meter: 19
dont make stupid things (hardware repair). first write a good pm, mostly the problem is due to pm(tested by me many times)
Old 06-04-2006, 18:47   #9 (permalink)
Member: 64002
Thanks Meter: 11
1. write good pm
2. Replace 32khz crystall clock
3. Reball hagar
4. Reball UEM
5. Reball Upp
Old 06-04-2006, 22:08   #10 (permalink)
Registered User
BouRRi_GSM's Avatar
Member: 111457
Thanks Meter: 967
or change mainboard
@celluniversal
u will be crazy when u read all these idea
Old 06-04-2006, 23:02   #11 (permalink)
Registered User
Member: 143939
Thanks Meter: 264
Remove hagar IC clean pin's or Change it.
Old 06-05-2006, 05:32   #12 (permalink)
Member: 139388
Thanks Meter: 98
in manual network search in phone shows no network found
Old 06-05-2006, 05:43   #13 (permalink)
Member: 261825
i think you chang uem ok.
Old 06-05-2006, 08:07   #14 (permalink)
Member: 119769
in this phone chec this.
1. reflash
full flash with ok PM file
2. rehot
RF IC
all FILTERS in rf part
DIPLEXER (antenna switch)
VCO
UEM
UPP
if tis not helps You have a broken PCB and Yours repairs dont help (it will help for 1 day , 1 month but it happens again)
Old 06-05-2006, 09:36   #15 (permalink)
Member: 73810
Thanks Meter: 2
buy another 3100
buy another 3100
sell batterie
sell cover original
sell lcd
sell frame
and change de mother board
Nokia N73 , 3g sometime, some time no network nakshatra Nokia Hardware & Hardware Repair 5 06-29-2013 13:27
E250 sometimes no service or searching.some time full network ,some time no network shahi NSPRO 1 02-20-2009 10:22
nokia 3100 no network obaid mobiles Nokia Hardware & Hardware Repair 7 12-13-2008 11:06
Nokia 3100 No Network azlanishak Nokia Hardware & Hardware Repair 9 12-07-2007 14:04
3100 no network Destructor Nokia Hardware & Hardware Repair 2 02-16-2004 16:29
Page generated in 0.26873 seconds with 9 queries
