10-31-2009, 13:58 | #32 (permalink) |
Junior Member Join Date: Oct 2009 Location: pak
Member: 1147956 Status: Offline Sonork: manzoorhunzai Thanks Meter: 1 | 3110c 3110 with charging solution in this link https://forum.gsmhosting.com/vbb/f148/nokia-3110-charger-not-supported-488372/ |
The Following User Says Thank You to janhunzai For This Useful Post: |
11-09-2009, 13:49 | #33 (permalink) |
Insane Poster Join Date: Apr 2006
Member: 255510 Status: Offline Thanks Meter: 15 | 3110c shows charging without charger Nokia 3110c shows on disply charging running without charger conected if it is on or off. if mobile is off if i connect the charger lcd goes blank. if i conect the charger in on condition it shows charging if i keep it for a 3days also it will be charging but it dosnt charge. any solution. pls reply |
11-13-2009, 09:35 | #35 (permalink) |
Member: 255510 Status: Offline Thanks Meter: 15 | i have tried with other chargers its not a charger problem its pcb problem. it shows charging if u plug or unplug the charger. exmp ; if you unplug the charger charging will be showing on the lcd it wil not stop. |
01-29-2010, 08:48 | #40 (permalink) |
Junior Member Join Date: Jan 2008
Member: 678371 Status: Offline Thanks Meter: 0 | 3110 Charging not Supported I had 3110c charging not supported problem. I Changed all posts you people are given in hosting. I also changed thavo.still facing same problem. any one give me correct Solution. |
01-29-2010, 13:49 | #41 (permalink) |
Freak Poster Join Date: Mar 2004 Age: 71
Member: 58466 Status: Offline Thanks Meter: 19 | first check if there is pm file in the fone.if it is there replace r2070 47kvoltage controlled resistor[not ordinary resistor].if problem is still there change i.c n6030.problem solved. |
02-05-2010, 06:18 | #43 (permalink) | |
Junior Member Join Date: Feb 2008
Member: 705112 Status: Offline Thanks Meter: 1 | 3110 contact service 3 Quote:
First do old software in 3110 like 5.00 than set will get dead. Now upgrade latest s/w 7.21 than unlock by BB5 Prince attached here 100% tested if face any problem contact to me for any help after this u will face charger not support for this problem write good pm without 308 field | |
The Following User Says Thank You to aashok_kkaushik For This Useful Post: |
3110 charger not supported | raknahs | Nokia Hardware & Hardware Repair | 2 | 01-30-2010 10:12 |
3110 charger not supported | heamanth | Nokia Hardware & Hardware Repair | 3 | 10-16-2009 08:27 |
3110 charger not supported pl help me | ruvanw1979 | Nokia Hardware & Hardware Repair | 5 | 06-20-2009 13:07 |
nokia 6085 charger not supported | dejanp | Nokia Hardware & Hardware Repair | 5 | 10-25-2008 10:36 |
3110 charger not supported ,how find this resistor | newstudent | Nokia Hardware & Hardware Repair | 2 | 07-24-2008 07:38 |
