Old 05-19-2009, 08:44   #1 (permalink)
gsmshare's Avatar
Member: 429569
Thanks Meter: 1,543
Arrow nokia 3110 lcd problem
hellooo dear frens my nk 3110 lcd 1st time blank after i chang display ic,,,now like this:http://www.usaupload.net/d/k1xkypi9iw7
pls help,,,,
The Following User Says Thank You to gsmshare For This Useful Post:
Old 05-19-2009, 08:55   #2 (permalink)
erick_ponsel88's Avatar
Member: 969971
Sonork: Vincent_Lim
Thanks Meter: 294
change another lcd bro....
i face the same problem like it.. try it n post result...
Old 05-19-2009, 09:03   #3 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274/mahbubalfa
Thanks Meter: 26,433
Bro.agin change 2 lcd ic..very heat the ic..
soldaring lcd conector...i m tested....
Old 05-19-2009, 09:19   #4 (permalink)
Member: 969971
Sonork: Vincent_Lim
Thanks Meter: 294
my 3110 also blank then i changed lcd ic and work but the problem is like you face.. so i change lcd and all fine.
cause if we used 6300 lcd to 3110 or 3500, we will face the problem like this
Shot with K810i at 2009-05-19
Old 05-19-2009, 09:51   #5 (permalink)
gsmshare's Avatar
Member: 429569
Thanks Meter: 1,543
thanks brother eric ponsoel88,,,,
you are absuletly right,,,,this is lcd problem,,
i solve it,,thanks again,,,,,
Old 07-21-2009, 13:58   #6 (permalink)
Member: 579916
Thanks Meter: 10
i change both ic connector also lcd still same problem biank display plzzzzzzzzzzzzzzzzzz help urgent
Old 11-10-2009, 12:19   #7 (permalink)
Member: 108483
Thanks Meter: 11
can you post hare whare we find the ic in 3110 boad
Old 11-10-2009, 12:35   #8 (permalink)
mahbubalfa's Avatar
Member: 1003058
Bro.try this solution.
http://forum.gsmhosting.com/vbb/showthread.php?t=826458
Nokia 3110 display problem mobileweed Nokia Hardware & Hardware Repair 12 05-06-2012 15:17
nokia 3110 light problem plzzzzzz????? firrozkhan_00 Nokia Hardware & Hardware Repair 16 02-22-2012 13:20
Nokia 3110 LCD pinout? ncmaothvez Nokia Hardware & Hardware Repair 3 10-05-2010 11:05
nokia 3110 lcd black but lcd ok solutuion saqib2020 Nokia Hardware & Hardware Repair 2 03-10-2009 16:14
nokia 3110 ringer problem sampathn Nokia Hardware & Hardware Repair 2 06-29-2008 20:21
Page generated in 0.18583 seconds with 9 queries
