nokia 3110 restart on inserting mmc. urgent anybuddy help, i,ve nokia 3110 which restarts or hang after inserting mmc.. i full flash phone with latest vesion files but all in vain:confused::confused::confused: |
replace your battery and reflash again. bestman |
oka i try this then i tell it work or not |
try to flash again bro but with new version files.tested to me :) Boim80 |
full flash must ok test by me many pcs oledi...100% |
CHEK THIS 3110 Restart Pro..sol... Any Friends U Have 3110c Restart I M Solv This Prob.. No More Idea Only One Write Cnt File Then Full Facktory Defult Good Result I Tested More 3110 C Phone .....good Luck..... http://forum.gsmhosting.com/vbb/show...highlight=3110 |
flash with latest flash file .. format memory card with system ..100000000% problem solve...tested in many 3110 c ... working fine |
PLZ FIRST FORMAT MMC with pc and chek niether chang mmc I CHECK THIS SOLUTION MANY TIME |
simply flash with latest version ur problem solved 100%. |
for solve the restart problem of nokia 3110 format the memory card from set ,and then format the set too with jaf,and then twice format the memory and set,and do not insert the memory into set upto i week,it is pure and sure treatment for nokia 3110 c |
Flash it with latest ver soft |
the problem is hard not soft |
just flash it with latest version and format mmc.. problem 100% solved br, yasir |
