the solution is not with flash the phone (because after flashing phone same problem) you have to format mmc or change it tested many time br |
...it is mainly complete of mmc if with out mmc it not have any problem ...so format the mmc in computer....... Then flash the phone or format the phone with *#7780# . If we format the mmc in computer the card will be correpted so the virus will not effect the phone affter flashing the phone format the mmc by using phone ........the complete will be solved ................( 100% tested in many phone's ) |
you can delete all applications and games , set factory defaults on phone , ELSE , format phone with jaf and mmc .. thanks |
motu naring pe kam .reh kam ku jenda mari pal |
Nice job , good work , |
format & reload mmc, flash phone with latest version.... if then also it restarts, then mmc ic.... good luck |
flash with jaf box before flash use file sys format atantion* before format fone save your rpl after flash right good pm and than unlock now your fone is ready to 111% ok |
change it lcd tested by and i use this set at this time |
checked mmc ..then format unit to jaf ,,.. |
yes ......reflash with new flash file working all the time |
Brother change silver mmc ic... Your phone okk tested by me |
i make flash but result same |
@babalsingh thank's bro this solve the problem ic is "r3200" |
