Nokia 3110c 6300 3500c Charging Solution 100% OK Nokia 3110c 6300 3500c Charging Solution Charging Ways Charging Tracks Charger Not Supported http://s55.radikal.ru/i150/1106/20/7cd88c8f9130.jpg |
It's Not A 100% Solution |
Good work Nice solution thanks |
what is 100% solution.. without analyzing the exact problem of the specific device how can any one give 100% solution unless there is only one component in the total circuit given. Do not assume that it is the only thing that is a problem. kiranm |
yes bro i support you but it is 99.99% perfect tested by me |
its not 100% solution this is only fack charging solution because if we do this charging show but not saved. |
*** solution keep it up mr.sujan br, AM_GSM_CELL...:::AWAIS.AS:::... |
Bor Charging Solution 100% Saved ------------------------------------------ Dear all gsm friend many Nokia 3110c 6300 3500c set Charging problam solved this ways if not anather problam in that set Thanks 2 All Pls Uor Click Charger Now Bir New Photos [IMG]http://2.bp.********.com/_4auVmb2b_eA/TEr4kidf96I/AAAAAAAAAbA/yoIo5stzARs/s320/6300charge4.jpg[/IMG] http://img87.imageshack.us/img87/823...kecharging.jpg |
http://img806.imageshack.us/img806/6696/111ci.jpg charging show but not saved try this http://img15.imageshack.us/img15/8381/3310pcb.jpg |
dear It's 100% tested Solution only work charging positive line missing |
Dear Charging Solution 100% Saved Click Charger |
brother say thanks only this is tested 100% 3110c & 7500 |
try to move capasitor... between the battery pin. there are 3 cap. an 3 ris. thers center the big cap. try to move on... good luck |
