Nokia 3110c Booting solution... Pls Help Nokia 3110c Phone Ok. Music Player Problem... Try To Flash But Phone Not Boot .... CMT 1ST Boot Err: Bad Resp RAPx, Rebooting Mobile Try To Usb Flash With... Library version: 1.0.0.9100(23-12-2010), 1.0.0.15151(24-12-2010) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Pooling for ADL device ... Timeout, no usb device found. Any Body Pls Help Me........ |
cheak your cable........................................... |
pls Help ............. |
battery must be fully charged. use charger when flashing coz stable voltage is needed |
try with 7pin cable............................. |
use mxkey flash usb on 7.30 |
clean pcb and try again |
Try all ... But same.............. Cable ok.. Usb or f-bus.... Pls help.. |
which error show fbus flashing? can u show me log:D |
CMT 1ST Boot Err: Bad Resp RAPx, Rebooting Mobile For Mx-Key With ufs ..... Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9100(23-12-2010), 1.0.0.15151(24-12-2010) Boot error: 03 00 72 00 - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. For Mx-Key With usb..... Library version: 1.0.0.9100(23-12-2010), 1.0.0.15151(24-12-2010) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Pooling for ADL device ... Timeout, no usb device found. also ...... USB Device Not Recognized.. |
power on the phone connect usb cable phone select mode(select nokia mode or pc suite mode) open any usb supprted software dont use dead usb,select flash file then flash it u need more help just contact me via yahoo i will help u:D |
u mean usb driver ESD? |
