Old 01-31-2011, 16:58   #1 (permalink)
rezwan_jack's Avatar
Member: 776103
Sonork: 100.1596478
Thanks Meter: 169
Arrow Nokia 3110c Charger Not Support need help
1. Changed Charger
2. Changed BL-5c Battery
3. Chaked Charging Ways
4. Replace R2070 47k
5. Rehot Thavo Ic
6. Reball Thavo Ic
7. Changed Software Version 7.21 set Dead
8. Changed software Version 7.30 set On
9. Write Full pm
Still Now Charger Not Support
The Following 3 Users Say Thank You to rezwan_jack For This Useful Post:
Old 01-31-2011, 18:15   #2 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274/mahbubalfa
Thanks Meter: 26,433
1. Changed Charger
5. Rehot Thavo Ic
6. Reball Thavo Ic
9. Write Full pm
1.Check bsi line.
2.change thavo ic.
hope your problem will be solve.
The Following 4 Users Say Thank You to mahbubalfa For This Useful Post:
Old 01-31-2011, 18:25   #3 (permalink)
Member: 754396
Thanks Meter: 913
Rehot Thavo Ic new ic 1000000000000%
The Following 2 Users Say Thank You to GSMONNITIN For This Useful Post:
Old 02-23-2011, 07:48   #4 (permalink)
gsmsoftek's Avatar
Member: 1326100
Sonork: 100.1591980
Thanks Meter: 39
check with mxkey,if supperdonglekey crupted then repair it cuz due to this also show charger not supported
good luck
The Following 2 Users Say Thank You to gsmsoftek For This Useful Post:
Old 03-27-2011, 19:22   #5 (permalink)
Member: 776103
Sonork: 100.1596478
Thanks Meter: 169
Arrow
Version Info:
MCU SW version: V 07.30 07-05-09 RM-237 (c) Nokia.
HW version: 5009
RFIC version: 17211721
DSP version: ICPR61_08w10
PPM version: V 07.30 07-05-09 RM-237 (c) Nokia. C
Retu version: 32
Tahvo version: 53
Content Pack version: Content: c_tr V 07.30 07-05-09 RM-237 (c) Nokia.
Bluetooth ID: 00 24 7D 6A E3 48
DVB-H receiver Bootloader version: H j
Product Info:
Production serial number: MPI062712
Product code: 0581521
Module code: 0203291
Basic production code: 0542523
Order number: 1111111
Serial Numbers:
IMEI plain: 3519630xxxxxxx
IMEI spare to net: 3A 15 69 03 13 64 25 05
IMEI SV to net: 33 15 69 03 13 64 25 25 F7
Other Info:
Model: Nokia 3110c (Classic Phone)
CS type: GSM900/GSM1800/GSM1900
BSI: 3.9 KOhm
Imei net: 3519630xxxxxxx
Version: SIMLOCK SERVER VERSION 63
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Rpl Backup
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 2D8001010E307E56BDFE1FFC8ACB54D5ABB6B1C4
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 10.6.0 revision: 0.0 size:
0x3C40
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000,
010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000,
030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101,
010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002,
001C192101001002
FlashID0: 0089 8981 - 0000 6A21 [Intel NU48F256,256 Mbits] type: NOR,CMT
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 10.28.0 revision: 0.0
030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000,
000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200,
000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101,
001C192101001002
CMT PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D
TransmissionMode: DDR&TX2
Reading CMT NPC (0x168 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x160 bytes).
Reading CMT HWC (0xD4 bytes).
Flash Imei: 35196303146525
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
SUPERDONGLE_KEY_DATA saved OK
WMDRM_PD_DATA saved OK
RF_DATA is empty.
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
BB_DATA is empty.
RPL saved to "C:\mobileEx\3.4\data\backup\BB5_3519630xxxxxxx_BA CK.rpl"
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.9274(01-03-2011), 1.0.0.15761(01-03-2011)
Product: V 07.30 07-05-09 RM-237 (c) Nokia.
Using cached productData[2D8001010E307E56BDFE1FFC8ACB54D5ABB6B1C4] ...
Calculating SUPERDONGLE using security server ...
SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.6
[CR2]BB5 remaining credit: 35
Completed in 6.594 s
RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM237_3519630xxxx xxx_SD.RPL" Updating SUPERDONGLE_KEY ...OK
Change = Thavo Ic
Full Flash with latest version
But Problem Still Same
The Following 2 Users Say Thank You to rezwan_jack For This Useful Post:
Old 03-27-2011, 19:42   #6 (permalink)
Member: 1097095
Thanks Meter: 5
Version Info:
HW version: 5009
Retu version: 32
Tahvo version: 53
Product Info:
Serial Numbers:
Other Info:
BSI: 3.9 KOhm
Counter: 0/3, 0/10
Rpl Backup
CMT Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
0x3C40
001C192101001002
001C192101001002
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
RF_DATA is empty.
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
BB_DATA is empty.
Change = Thavo Ic
You should do sx4 than, write pm 1 and 309
The Following 2 Users Say Thank You to .:kirara:. For This Useful Post:
Old 03-29-2011, 09:06   #7 (permalink)
trmobile2's Avatar
Member: 1483660
Sonork: 100.1601918
Thanks Meter: 155
try this ways
Old 03-29-2011, 09:07   #8 (permalink)
GSMPAKHOST's Avatar
Member: 1516950
Sonork: 100.1593505
Thanks Meter: 5,750
1.Check bsi line.
2.change thavo ic.
Old 03-31-2011, 16:01   #9 (permalink)
Saggio Fenola's Avatar
Member: 1342669
Thanks Meter: 109
check out this line ...
Old 03-31-2011, 16:41   #10 (permalink)
Member: 776103
Sonork: 100.1596478
Thanks Meter: 169
Thnx for reply
This solution Chacked & Changed
problem same
Charger not support
Old 03-31-2011, 21:15   #11 (permalink)
ramjan_777's Avatar
Member: 1226253
Sonork: 1602755
Thanks Meter: 69
first change thavo ic
2nd re hot rap ic
tray thisssssssss
Old 03-31-2011, 22:07   #12 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
change retu ic and post result
Old 04-01-2011, 04:55   #13 (permalink)
rekha1255's Avatar
Member: 333796
Sonork: 100.1587155
Thanks Meter: 83
Yes i agree with u "HUM"
manytime retu intenly sort n giving charging problem .
Old 06-25-2011, 17:01   #14 (permalink)
Member: 289307
Thanks Meter: 44
try to move capasitor... between the battery pin. there are 3 cap. an 3 ris. thers center the big cap. try to move on... good luck
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 05-26-1999 11:35
Page generated in 0.39055 seconds with 9 queries
