Old 04-07-2010, 09:18   #1 (permalink)
waqas317's Avatar
Member: 1147735
Thanks Meter: 156
nokia 3110c charging show but not charging
nokia 3110c charging show but not charging.I changed battery but still.Fuse and coil ok .
The Following User Says Thank You to waqas317 For This Useful Post:
Old 04-07-2010, 10:04   #2 (permalink)
rakib_sheak's Avatar
Member: 1201843
Thanks Meter: 487
click by thankssssss
The Following 4 Users Say Thank You to rakib_sheak For This Useful Post:
Old 04-07-2010, 11:36   #3 (permalink)
d.jain's Avatar
Member: 670629
Sonork: 100.1590208
Thanks Meter: 431
yes chang tahvo ic youre set is 1000000000000000000% ok
The Following User Says Thank You to d.jain For This Useful Post:
Old 04-07-2010, 11:49   #4 (permalink)
asimbutt's Avatar
Member: 394146
Thanks Meter: 56
ya it will ok by changing Tahvooo
The Following User Says Thank You to asimbutt For This Useful Post:
Old 04-08-2010, 08:30   #5 (permalink)
Member: 1245514
Thanks Meter: 2
Cool
[QUOTE=waqas317;5678481]nokia 3110c charging show but not charging.I changed battery but still.Fuse and coil ok .
change tha thavo i.c. youe probleme is solve
The Following User Says Thank You to rahulmob. For This Useful Post:
Old 04-26-2010, 17:18   #6 (permalink)
Member: 581267
this was good i liked the co operation of gsm solutions
Old 05-23-2010, 11:07   #7 (permalink)
waqas317's Avatar
Member: 1147735
Thanks Meter: 156
Old 05-23-2010, 12:59   #8 (permalink)
aslamkalikavu's Avatar
Member: 1281494
Thanks Meter: 120
3110
Old 05-23-2010, 18:25   #9 (permalink)
Member: 1308936
Thanks Meter: 88
yes change thavo ic your problem is solved.
Old 05-24-2010, 04:52   #10 (permalink)
suraj9860607689's Avatar
Member: 787710
Sonork: not using
Thanks Meter: 771
Old 05-24-2010, 06:59   #11 (permalink)
Member: 1201843
Thanks Meter: 487
thanksssssssssss all member
Old 05-24-2010, 07:05   #12 (permalink)
Member: 393725
Sonork: 100.1602458
Thanks Meter: 81
rehot your tahvo ic and see if your problem solved other wise change it .good luck
nokia 3110c ... always shows card not formated ... ashoka_ashok Nokia Hardware & Hardware Repair 7 01-05-2013 08:22
nokia 3110c charging show but not charging umesh garg Nokia Hardware & Hardware Repair 28 02-25-2012 12:48
6600 charge show but no charge Deb Chandan Nokia Hardware & Hardware Repair 6 10-05-2009 17:39
nokia 3110c charging show but not save drjaved_akhter Nokia Hardware & Hardware Repair 3 06-17-2009 16:00
8330 charging show but not charged parveen kumar LG 0 12-29-2005 14:17
Page generated in 0.17865 seconds with 9 queries
