Old 10-26-2009, 13:21   #1 (permalink)
Member: 340774
Thanks Meter: 164
nokia 3110c contact service
nokia 3110 showing contact service.. i also full flash the phone but it is not working....... i,m using mx key and ufs
The Following User Says Thank You to vinkle For This Useful Post:
Old 10-26-2009, 13:33   #2 (permalink)
Member: 823633
Thanks Meter: 1,640
bro try
1 cyclone box
2 ub box
3 sx4 authorize
4 write good pm file
5 unlock
The Following 3 Users Say Thank You to vaghubha_sodha For This Useful Post:
Old 10-26-2009, 13:37   #3 (permalink)
Member: 340774
Thanks Meter: 164
but i already told here i ve only mx key and ufs 3
Old 10-26-2009, 13:38   #4 (permalink)
sagg_4u's Avatar
Member: 884540
Thanks Meter: 684
bro flash wid higher version then write gud pm file then unlock
100% solve......
then post result.....
thnx
Regard:
Sagg_4u
The Following User Says Thank You to sagg_4u For This Useful Post:
Old 10-26-2009, 13:41   #5 (permalink)
Member: 823633
Thanks Meter: 1,640
bro try
to use mx key sx4 authorize tab click & write good pm file .unlock brother
The Following User Says Thank You to vaghubha_sodha For This Useful Post:
Old 10-27-2009, 05:31   #6 (permalink)
Member: 1087914
Thanks Meter: 7
if doesent work with flash chang sim ic / display & check
Old 10-27-2009, 05:58   #7 (permalink)
rakesh15's Avatar
Member: 1019591
Sonork: 100.1592733
Thanks Meter: 633
contact service is not problem of flash
if you use mxkey first scan and see result , if your sim lock area is valid then
do pm auth and write pm it will be 100%ok
if you dont know how to use
contact
[email protected]
Old 10-27-2009, 06:03   #8 (permalink)
Registered User
Member: 798123
Sonork: 100.1611781
Thanks Meter: 33
ok if u have mxkey read full beckup then write modified pm(removed308) with sx4 .. ur prob . is solve if imei is ok
Old 01-07-2010, 08:54   #9 (permalink)
Member: 502848
Thanks Meter: 6
Hi frnd plz till me how to solve the contct service problem
Old 01-07-2010, 09:01   #10 (permalink)
Member: 502848
Thanks Meter: 6
3110c contct service
The Following User Says Thank You to sardarmobile For This Useful Post:
Old 01-07-2010, 09:06   #11 (permalink)
Member: 975117
Sonork: rivacomcell center
Thanks Meter: 45
check info bro..
if SL Data Corrupt..unlock SL Data with Zulea Crack
if imei only oke..problem contact service solve with this solutions.
post me result bro..
Old 02-12-2010, 07:10   #12 (permalink)
phone2world's Avatar
Member: 622862
Thanks Meter: 47
Hello friends, Please let me know the solution using mxkey/ub/jaf/hwk/cyclone
Phone Type: RM-237 (Nokia 3110c)
SW Version: V 07.21 05-11-08 RM-237 (c) Nokia.
Imei plain: 3552xxxxxxxxxxxx
Product Code: 0544325
Language Pack:
- not available.
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 3552xxxxxxxxx
Version: SIMLOCK SERVER VERSION 63
Counter: 0/3, 0/10
CONFIG_DATA: FFFFFFFFFFFFFFFF
PROFILE_BITS: FFFFFFFFFFFFFFFF
BLOCK 1: 1=CORRUPTED
this one is 3500c
Original Imei: 35xxxxxxxxxxx
Original Product code: 0567037
Bluetooth ID: 0021FEF2B4DF
Phone Type: RM-272 (Nokia 3500c)
SW Version: V 07.21 05-11-08 RM-272 (c) Nokia.
Imei plain: 355xxxxxxxxxxxxx
Product Code: 0567037
Language Pack:
- not available.
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 355xxxxxxx
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
both are showing contact service
The Following User Says Thank You to phone2world For This Useful Post:
Old 04-09-2010, 16:16   #13 (permalink)
Member: 904809
Sonork: 100.1615464
Thanks Meter: 729
ulock it ,and will be ok,,
Old 04-09-2010, 16:16   #14 (permalink)
Member: 904809
Sonork: 100.1615464
Thanks Meter: 729
update simlock, with mxkey,,,tested
The Following User Says Thank You to alkhaleejmobile For This Useful Post:
Old 05-14-2010, 06:28   #15 (permalink)
Member: 1032503
Thanks Meter: 15
Originally Posted by VM_SODHA View Post
bro try
1 cyclone box
2 ub box
3 sx4 authorize
5 unlock
can u help plz???
3110c contact service, taken backup of gud pm from ok 3110
writing pm but pm1 written fail pm 308 is writing gud,,,
wat is the possible reason.
no water damage, no dropping of cell,,,
Nokia 3110c Contact Service AtharavK Nokia Hardware & Hardware Repair 9 12-13-2009 13:23
nokia 3110c contact service need quick reply vinay_ab123456 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 7 11-30-2009 11:05
nokia 3110c contact service please help me prakash40 Nokia Hardware & Hardware Repair 5 11-06-2009 13:50
please helpe me ....nokia 3110c contact servic,?????? holacobob Nokia Base Band 5 ( BB-5 ) 4 10-25-2009 12:10
Nokia 3110c Contact Service Problem rubel_chk007 Nokia Hardware & Hardware Repair 2 08-01-2009 16:02
Page generated in 0.42578 seconds with 8 queries
