05-05-2009, 22:12 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Location: KOLKATA Age: 51
Member: 102582 Status: Offline Thanks Meter: 72 | Nokia 3110C Flashing Problem...Pls. Pls. Help.. One dead 3110C came to me. There was a digital short on the battery connector. So, I removed that short and the set is on now. Just one day back I have purchased a new GPG 6300 Cable of Red color and just made the UI SETTINGS and it worked fine with V 7.01 already installed in the phone. After that I just tried to upgrade the set and suddenly it started showing the following error time and again : " 1ST BOOT : C0,07 [Rm-237] [2.0.8.4] RAPx ID : 000000010000022600010006010C192101001101 EM 1 ID : 00000232 EM 2 ID : 00000353 RAPx PBID : 206000019E887C56EA07515B384FE01DC2B9AD40 RAPx MODE : 00 RAPx HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 RAPx ROID : 191EC665DFAAF68F CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1 CMT FLID0 : 00898981-00006A21, Int NU48F256 CMT FLCNT : 000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo.fg, Ver: 9.11.0 CMT VPP : Internal DUAL LINE : True CMT ALG Boot OK IMAGE : rm237__06.01.mcusw CMT NOR Erase Area: 0x00000000-000006BF CMT NOR Erase Area: 0x000006C0-0001FFFF CMT NOR Erase Area: 0x00020000-0007FFFF CMT NOR Erase Area: 0x00080000-000DFFFF CMT NOR Erase Area: 0x00100000-001FFFFF CMT NOR Erase Area: 0x00200000-0031FFFF CMT NOR Erase Area: 0x00320000-0105FFFF CMT NOR Erase Area: 0x01060000-01067FFF CMT NOR Erase Area: 0x01068000-0107FFFF CMT FLASH ERASE OK, Time: 00:01 DATA_BLK_ERROR at: 0x00020000, 00 ERR: CMT FLASH WRITE D_BLK 000000000000000910000000B172, LN: 0x000280, Time: 00:04 Process Failed, Repowering Mobile " But all of a sudden, it started giving error message as following : " CMT 1ST Boot Err: Bad Resp RAPx, Rebooting Mobile " What's the problem? Is this CABLE FAULT or HARDWARE i.e. FLASH IC fault? Pls. suggest as early and as accurately possible. Advance thanks to all. amit123 |
05-06-2009, 07:19 | #8 (permalink) |
No Life Poster Join Date: Oct 2008 Location: chennai
Member: 880497 Status: Offline Thanks Meter: 197 | http://www.shrak-mobile.com use this link for latest exe and try to flash with that and use a proper cable,good luck |
05-07-2009, 16:13 | #11 (permalink) |
Member: 102582 Status: Offline Thanks Meter: 72 | Dear Friends, Thanks for your comments. I have solved this problem by flashing it with 10 PIN Cable coming with MT-BOX. Now the phone is alive once again. Thanks once again for all of ur valuable comments. amit123 |
Nokia 3110C flashing problem | James_S | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 03-12-2010 02:15 |
Nokia 3110c Flashing Problem...... | Saleemsmj | Nokia Hardware & Hardware Repair | 4 | 12-21-2009 15:06 |
Nokia 3110c flash problem | wase | Universalbox | 10 | 04-14-2009 20:56 |
