nokia 3110c phone restricted how to fix this problem..plz help team members. i flash full but same problem.....what to do........ |
reset all factory setings ........... |
update simlock bro.............. 100 % tested many time. |
which box use bro use atf dairect unlock sl 2 bro ur solution |
Repair SD key & update Sl Data. Your Problem 101% Soul................. |
Bro use mx.atf.cyclone.ub.jaf zulia crack.best Unlock only done. |
update simlock bro............ |
use mx key,atf,cycolne in mxkey try it go in service > Imei&security tick Make simlock RPL then Update Sp lock (mx-key) |
by ATF box do sim lock repair |
@Roshan chauhan its enough ans for you .. next time post in correct place also try search... thanks br snmobilecenter |
read here your solution Quote:
fenixkey rpl unlock 100% solve other post is helpful & ok solution ..........bro |
Thanx bro its work ..............................now phone is working fine |
